Old 06-12-2014, 01:52 PM   #1
1977 27' Overlander
Malibu , California
1977 Overlander 27 foot - Help please
The right rear tire doesn't spin. I was told I need right rear bearing.
Can someone please explain to me what this means? And is it expensive?
Can the trailer be towed without the wheel moving? I need to have it towed and since I will not be keeping the trailer, I do not want to spend a lot of $.
abalonebabe is offline   Reply With Quote
Old 06-12-2014, 02:04 PM   #2
1977 27' Overlander
Malibu , California
Wheel Bearing 1977 Overlander 27 foot
Can the trailer be towed without the right rear wheel moving? I need to have it towed and since I will not be keeping the trailer, I do not want to spend a lot of $.
Old 06-12-2014, 02:12 PM   #3
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
The bearing and race maybe 20 bucks install 50 labor and yes you want to get it fixed if you did the bearing then 25 bucks, 20 for the bearing and 5 for grease.
You tube it!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 06-12-2014, 02:12 PM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
If it's only a short distance you might get away with removing the tire and letting the
hub / drum hang. I would not even begin to suggest this for more than a few miles since it would put all the weight on the remaining tire. If you had the means to replace the bearings yourself, NO, it is not expensive. A new set of bearings might run in the neighborhood of $20-$30 or so. To pay a mechanic to come to your door and do it might put it into the neighborhood of expensive. To bring a transporter in to move it for you would surely be in the $$$ area.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-12-2014, 06:36 PM   #5
1981 31' Excella II
New Market , Alabama
The brake could be rusted to the drum as well. How far you planning on pulling it?
Perry
Old 06-12-2014, 06:54 PM   #6
1966 17' Caravel
Just how mechanically inclined are you? Bearings are not difficult and brakes are also not that bad both can be found on you tube and although you will get a little soiled but I hear that it makes cold beer taste better!
Cliff
Old 06-13-2014, 09:52 AM   #7
1977 27' Overlander
Malibu , California
Perry
We have had our airstream parked on the rear of a property in Malibu, CA (by the coast) and we are planning on either selling cheap for someone to restore or donating it. Our location is limited regarding obstacles and road width for a huge tow truck to get it out of here.
I'd say we have to pull it about 1/4 mile off the private property to the street where it can then be loaded onto a tow truck.
It sounds like removing the tire would be a good idea.
Old 06-13-2014, 10:38 AM   #8
1981 31' Excella II
Remove the tire and go slow and you should be ok.
Perry
Old 06-13-2014, 10:45 AM   #9
1977 27' Overlander
Malibu , California
Thank you. That is a great idea since I only have to have it towed by pickup off a private property and onto the street where it can be loaded on a big, big tow truck. I am planning on donating it or if I find someone interested in it for restoration that's an option too.
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
