Old 05-09-2011, 09:46 PM   #1
Mr & Mrs S's Avatar
Newton , Texas
Wheel and tire Combo
I know theres a lot floating around about the best tire and wheel combo.
Im looking to upgrade to 16'' Rims and Tires. I think I found a wheel and tire combo that I willing to try out but I would like for someone to double check me so that Im not making a costly mistake.
This is for a 1993 AS Excella 29 footer.
This is the wheel Im looking at buying
16 inch SAWTOOTH Aluminum Trailer Wheel 6 Lug
Its rated for 3200 lbs and is 6 lug x 5.5 with a 4.25 bore with a 0 offset.
This should fit right?
This is the tire Im looking at going with.
Michelin LTX M/S
Its a load range E tire. Might be alittle overkill but should work right?
Any suggestions or guidence would be great. Thanks for any input.
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Old 05-09-2011, 09:53 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Great choice. Nothing better.
Lance
Top is offline   Reply With Quote
Old 05-09-2011, 10:10 PM   #3
Mr & Mrs S's Avatar
Newton , Texas
Thanks Top,
Was really just making sure the rim is the correct size, I feel like Im kinda over doing it alittle but Im not a big fan of the ole beauty rings thats on the AS now and since Im buying rims might as well go for 16'' to get a bigger selection. Guess thats the combo Im going to go for.
MR. & MRS. S
Wheel well plastic jcessna Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 12-12-2011 08:56 PM
Wheel saga -tubes and flaps hertfordnc Wheels, Hubs & Bearings 25 04-29-2011 11:24 PM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 07:50 PM
wheel for 67 eubank Wheels, Hubs & Bearings 5 03-06-2011 03:39 PM
On-axle tire and wheel balancing Jammer Wheels, Hubs & Bearings 8 02-16-2011 05:56 PM
