Old 05-12-2014, 11:24 AM   #1
2001 34' Limited S/O
Betterton , Maryland
Wheel aligment
I'm having a tire wear issue on the curb side front axle on my 34' trailer - excessive wearing of the outer portion of tire. I am scheduled to attend the International Rally in Gillette, WY and can not get an appointment at Jackson Center before mid July. I live in Maryland and was hoping someone may have a recommendations on a shop that can handle the alignment between my home and Gillette, WY.
clydewarden is offline   Reply With Quote
Old 05-12-2014, 11:37 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Get in touch with Gaumers on Chambersberg Pa.
717 263 1882
In the past I have arrived late afternoon and they have an AC line for the night and will take you in first thing in the am. It is about a 4 hour job.
If you do not use them fins a truck axle shop. Under no circumstances go to Jackson Center.
2004 Excursion 4x4
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
Four Wheel Drive or Two Wheel Tow Vehicle? 1cericks1 Tow Vehicles 24 02-01-2009 02:22 PM
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
The Junkyard Wheel Story Inland RV Center, In Wheels, Hubs & Bearings 1 04-10-2002 06:04 PM
Wheel assembly balancing - which method?? 83Excella Wheels, Hubs & Bearings 0 03-23-2002 07:53 PM
