Old 04-13-2004, 06:44 PM   #1
North Central , USA
What wheel size, '04 w/15" tire?
I need to buy a new wheel (for a spare) & went to the local tire place. Without bringing the trailer or a wheel to compare, they said I needed to know what the spacing distance for the 6-bolt lug pattern was as well as the 'offset'. Apparently knowing it is a 15" tire/wheel with a 6-bolt pattern is not enough. Any help appreciated.
RivetED is offline   Reply With Quote
Old 04-13-2004, 11:36 PM   #2
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
Ed you might try your spare off of your Ford it might fit. Just kidding !!!
Call Caple Shaw in Fort Worth they are up by the stock yards they carry all kinds of trailer parts. I buy from them all the time and they will have what you want at a fair price . If have any questions give me a call.
Andrew Selking
WBCCI #6062 VAC
Andrew Selking is offline   Reply With Quote
Old 04-14-2004, 10:41 AM   #3
ctdair's Avatar
somewhere I read a post stating that there was a difference in the rims for the airstreams(or other trailers for that matter) and a "regular wheel would fail". search the forum and verify.
some wheels center on the hubs and some on the lug bolts. there was even a picture in the post of a ugly rim failure. I know it will cost but better safe than sorry , order rim from airstream would be best bet.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 04-14-2004, 11:17 AM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Check this out for a spare - another forum member purchased these recently.
http://www.rjays.com/Wheels/hi-spec-wheels-01.htm
I think it was 59toaster
Uwe
www.area63productions.com
Old 04-16-2004, 05:31 PM   #5
North Central , USA
Uwe, thanks for the link. Those are just what I'm looking for. At $90.- that's $70.- less than the dealer ($160.- for alloy).
Old 04-16-2004, 06:28 PM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I got mine from American Racing, but they are very similar to the ones pictured. Mine have little rivets around the perimeter, which I thought was fitting.....
The weight rating surely looks good on the ones in the link.
Uwe
Old 04-20-2004, 07:55 AM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
RV Wrecking yard
Buy a good used one at an RV wrecking yard and spend the diff on the tire.
>>>>>>>>>>>>Action
'66 Tradewind wheel bearing size? dreamqueen 1959-69 Tradewind 1 02-18-2004 06:13 PM
Tire Size rcaldwel Tires 1 11-04-2003 07:39 AM
20 MH Tire size? Don B Airstream Motorhome Forums 7 09-29-2003 06:45 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
