Old 08-30-2017, 09:48 AM   #1
Mollysdad's Avatar
What size lug nut?
Is there a standard size lug nut on an Airstream?
I want to buy a socket for my breaker bar to keep handy.
Old 08-30-2017, 10:40 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There are at least two standards. I'm not at the trailer at the moment so I can't look at what I have. You want a six point socket not a twelve.
If you get a socket for the lug nuts, consider that the "fancy ones" have a plastic shield on them to protect the pretty wheels. I can buy an entire set at the local big box store for what one of them runs ....
Old 08-30-2017, 10:56 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Some are 3/4", but others, including mine are 13/16".
Ray B.
Adventure.AS is offline   Reply With Quote
Old 08-30-2017, 12:33 PM   #4
Half a Rivet Short
Hi
If you are going to get retentive about the tire process, you also need a torque wrench. Remember to re-torqe the lug nuts at 10, 25, and 50 miles ... or was it ...10, 20, 30 ...
Old 08-30-2017, 12:53 PM   #5
Mollysdad's Avatar
Hi
I do have a torque wrench. (even though I've never torqued a lug nut in my life nor do I know anyone who has and I've never had one fall off.) But never mind that right now. Maybe torque wrenches cause loose nuts?
BTW, Nascar torques lug nuts before every race. During the race, never, since they're put on with an air gun in 12 seconds, and the studs are extra long so the nuts (glued to the rims) are aligned when hit with the air gun for .5 second. Lug nuts are checked after the race, but only to verify they have five, not that they're tight.
Old 08-30-2017, 02:03 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Easiest way to determine what size you have is to try your available sockets to see what fits. I prefer to use impact sockets for lug nuts as they are made to higher tolerances than most off the shelf sockets. Ditto on the quality torque wrench. Use it before every trip. Comparing race team usage to trailer use is apples and oranges as far as I am concerned. Good luck and happy torquing.
Old 08-30-2017, 02:12 PM   #7
Mollysdad's Avatar
Thanks, I won't pick it up until a week from Friday, so I can't just look. I wanted to have a socket handy just in case for the trip home.
I Googled and found a site that claimed that after 2000 Airstream changed to 3/4".
Old 08-30-2017, 02:52 PM   #8
2018 25' International
East Northport , New York
I picked up a set of reversible sockets to keep on my truck. Covers all bases.
James
Biker is offline   Reply With Quote
Old 08-30-2017, 03:08 PM   #9
Mollysdad's Avatar
Attachment 293580
How do those work? An extension goes into the middle and the sockets are shallow?
Old 08-30-2017, 03:43 PM   #10
Yes, the 3" extension
James
Old 08-30-2017, 03:45 PM   #11
Oops...
Yes, the 3" extension goes through the side you aren't using.
James
Old 08-30-2017, 06:03 PM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I do torque mine and retorque after 50 or so miles. I always get a few that can be tightened a bit, but nothing serious. I've also checked after 50 mile and never had to adjust.
2019 Ford Expedition Platinum
Old 08-31-2017, 11:37 AM   #13
Here is a picture of the extension inserted into the socket. My 2017 23FB came McGard lug nuts and they are 13/16.
James
Old 08-31-2017, 11:37 AM   #14
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
I also re-torque the wheel nuts after getting the truck or trailer back from maintenance if the wheels have been rotated.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 08-31-2017, 11:37 AM   #15
Framingham , Massachusetts
My 2017 25 FB International (with upgraded 16" wheels and Michelins) uses a 13/16" socket for the lug nuts (which are the solid ones, not the ones with the cheap covering that comes loose). YMMV...
quietguy is offline   Reply With Quote
Old 08-31-2017, 12:11 PM   #16
Mollysdad's Avatar
Since there was some doubt, I ordered a deep impact socket in both 3/4" and 13/16". Should have them today.
Old 08-31-2017, 03:04 PM   #17
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Lugnut stud is 1/2" x 20 Threads per Inch (TPI).
As others have said, 3/4" 6 point thin wall deep socket will work best for loosening/tightening.
Greg
greghoro is offline   Reply With Quote
Old 08-31-2017, 07:54 PM   #18
2017 30' International
Lincolnwood , Illinois
I found 3 loose nuts on my last trip of 2400 miles.
Perhaps the idea is torque to make sure you do not over tighten and damage the threads.
I always check before leaving on a trip and then again 1/2 way through.
Milo1952 is offline   Reply With Quote
Old 08-31-2017, 08:22 PM   #19
Half a Rivet Short
Hi
You can spend a lot of time going back and forth on the value of re-torquing (as opposed to re-tightening) nuts or bolts. There is a school of though that says a torque spec is only met if you start from "loose". In this case I'd say that's a really bad idea ....
Old 08-31-2017, 09:21 PM   #20
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by adventure.as View Post
some are 3/4", but others, including mine are 13/16".
2016 30' fc: 13/16".
MelGoddard is offline   Reply With Quote
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 05:18 PM
Lug Nut Size topfish Tires 3 08-05-2010 08:20 PM
Lug nut size Whirlaway Wheels, Hubs & Bearings 4 04-17-2007 08:10 PM
Lug Nut Size?? Steve Heywood 1997 -2001 Excella 3 08-16-2005 01:24 PM
Lug Nut Size AYRSTRM2 Axles 0 08-17-2004 01:27 PM
