An Airstream well it isn't Nascar- And a air gun in a shop unless using a torque stick with a calibrated air supply will not provide the proper tightening hold. For some reason flat rate or ego many do not use a torque wrench correctly.
Torque wrenches are used to stretch the wheel bolt to the proper yield so it always is twisting to stay tight. To loose they back and off to tight they can snap a stud. Most high end trained techs use a torque wrench. Those Nascar air guns have been tested with the air supply length of the hose and gun itself. They are calibrated with exact or very close torque to the correct ft lbs numbers. You must not hang with techs if you have never seen one used.
Originally Posted by Mollysdad
I do have a torque wrench. (even though I've never torqued a lug nut in my life nor do I know anyone who has and I've never had one fall off.) But never mind that right now. Maybe torque wrenches cause loose nuts?
BTW, Nascar torques lug nuts before every race. During the race, never, since they're put on with an air gun in 12 seconds, and the studs are extra long so the nuts (glued to the rims) are aligned when hit with the air gun for .5 second. Lug nuts are checked after the race, but only to verify they have five, not that they're tight.
