Old 08-31-2017, 09:32 PM   #21
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Hi
You can spend a lot of time going back and forth on the value of re-torquing (as opposed to re-tightening) nuts or bolts. There is a school of though that says a torque spec is only met if you start from "loose". In this case I'd say that's a really bad idea ....
Bob;
The proper way to torque a nut is to start, not from "loose", but snug.
THEN go all the way up, smoothly and slowly, until the wrench 'clicks'.
Use the 'Star' pattern, as you tighten them up, and then go a 'Round Robin' to confirm the bolt tensions.
Like others have said; If the wheel has been off for any reason, the general wisdom is to recheck the torques at 50, 100, 200 miles and everytime you hit the road, on a new trip.
MelGoddard is offline   Reply With Quote
Old 09-01-2017, 09:40 AM   #22
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by MelGoddard View Post
Bob;
Hi
Snug or loose is *not* the same thing as tight. If they have been torqued once before, they are neither snug nor loose ....
Old 09-01-2017, 08:57 PM   #23
Hi
Read the note again!
I'm talking about starting to torque up a nut, and finishing tightening it.
Obviously, one starts with a loose nut!
If one is just checking the torque, of course, you are right.
Old 09-02-2017, 09:32 AM   #24
Half a Rivet Short
Hi
Well speaking of "read the note", this is all in reference to re-torquing the bolts every 10 miles .... just saying .... (Yes I suppose it would be more fun if I used a lot of bold text and all caps)
Old 09-02-2017, 09:19 PM   #25
hi
well speaking of "read the note", this is all in reference to re-torquing the bolts every 10 miles .... Just saying .... (yes i suppose it would be more fun if i used a lot of bold text and all caps)
bob
Old 09-03-2017, 09:36 PM   #26
ďOne test is worth a thousand 'expert' opinionsĒ
Sign at Boeing headquarters, posted by test pilot Alvin ďTexĒ Johnston, c1948
"But will it work in Flin-Flon?"
Sign on the desk of Donald Douglas, after watching mechanics working on a snag on a DC-4 in Flin-Flon, Manitoba, in the dead of Winter. (Temps. Minus 'Heart Attack Blue'.)
Old 09-04-2017, 12:09 AM   #27
2007 22' International CCD
What size lug nut?
Tex is still a legend at Boeing. (I tetired after 20 at Boeing). It's an amazing culture in the engineering end of the business.
Old 09-04-2017, 07:23 PM   #28
I retired from DeHavilland/Bombardier in 2002, after 25 years as a Flight Service Engineer.
Our "legend" was George Neal, who was test pilot on the DHC-2 Beaver, as well as subsequent aircraft.
THIS guy was excellent 'hands & feet'; built several of his own aircraft.
Passed away last year at age older than me.
"Engineering", of course, had their own 'culture'; but that can be said for any engineering group.
Old 09-05-2017, 12:21 PM   #29
One of my best bosses referred to managing engineers as akin to "herding cats".
Old 09-05-2017, 07:42 PM   #30
NICE ONE
Old 09-05-2017, 08:13 PM   #31
1990 25' Excella
St Lawrence , Pennsylvania
I also have four sections of 1.5 inch diameter pipe 8 inch long with pipe fittings to connect all sections
This all fits in the tool bag.
The pipe becomes the breaker bar extender.
It is always the truck wheel that the breaker bar alone will not loosen.
rjmaype is offline   Reply With Quote
Old 09-06-2017, 08:54 AM   #32
2017 30' International
Lincolnwood , Illinois
Uncle Bob
When I say loose, they are snug but not to specs. when I check the nuts I apply even pressure until it clicks. I do this to all my Lug nuts. Why would this not be a good idea?
To suggest unsnugging all the nuts just to retighten them all is better doesn't sound like a good idea to me.That is akin to taking all the wheels off just to put them back on. The nuts that don't move click without moving. Hence tight enough. What is " not a good idea ?" Is it better not to check and leave them loose?
Milo1952 is offline   Reply With Quote
Old 09-06-2017, 09:28 AM   #33
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
Been replacing mine slowly
Originally Posted by Mollysdad View Post
Is there a standard size lug nut on an Airstream?
I want to buy a socket for my breaker bar to keep handy.
Its good to have the right socket and a good long half inch drive ratchet or breaker bar. I have a four-way lug wrench I keep in the truck.
I have been buying the Mcgard 'premium' triple nickel-chrome lug nuts,
part number 64010.
They are 1/2"x20, and I just checked 3/4" hex socket fits.
The good thing is, the same nut that fits the AS also fits both of my Jeeps. I have been replacing those too along with the AS, because the Jeeps came with those 'BS' two-piece lug nuts.
I get the tall Mcgard 'acorn-type' ( 64010) to make sure they are deep enough not to bottom out on the studs.
They are heavy duty.
hope this helps, stay safe out there.
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 09-06-2017, 09:49 AM   #34
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
Originally Posted by Milo1952 View Post
Uncle Bob
If you insist on a torque wench......
Note the last paragraph
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
Sweet Streams....🌥
Old 09-06-2017, 11:23 AM   #35
Mollysdad's Avatar
Well, a torque wrench only works in the "tighten" direction.
If you already have the correct torque, the wrench won't indicate anything, so you have overtightened them. To avoid this, people loosen the nuts a little, then tighten them until it clicks.
Mollysdad is online now   Reply With Quote
Old 09-06-2017, 02:54 PM   #36
Well thats factually untrue....both mine work in both directions. Notice the on/off on the Snap-on and the scale on both sides of the beam on the BluePoint.
ID:	294192   Click image for larger version
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 09-07-2017, 09:12 AM   #37
Half a Rivet Short
Hi
You have static friction and dynamic friction. Basic physics. Your torque specs are all written or a "moving" bolt (dynamic friction). Once you get them down, they are stationary. If you put a torque wrench on them it will read the static friction. That is inevitably higher than what it would be in motion. Re-torquing a bolt may be fun. It can make you feel good. If it does not move, you really don't know a lot about it's state.
Old 09-10-2017, 07:24 PM   #38
hi
you have static friction and dynamic friction. Basic physics. Your torque specs are all written or a "moving" bolt (dynamic friction). Once you get them down, they are stationary. If you put a torque wrench on them it will read the static friction. That is inevitably higher than what it would be in motion. Re-torquing a bolt may be fun. It can make you feel good. If it does not move, you really don't know a lot about it's state.
true!😉
Old 09-17-2017, 01:02 PM   #39
2018 27' Flying Cloud
Jacksonville , Florida
What's the best way to determine the proper amount of torque?
Doodad is offline   Reply With Quote
Old 09-17-2017, 06:10 PM   #40
DewTheDew's Avatar
2017 27' Flying Cloud
Frederick , Maryland
The owners manual tells you. I just looked at the 2017 FC and for aluminum wheels it is 110 lb-ft and for steel wheels it is 100. It's in the table with all the dimensions
DewTheDew is offline   Reply With Quote
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 05:18 PM
Lug Nut Size topfish Tires 3 08-05-2010 08:20 PM
Lug nut size Whirlaway Wheels, Hubs & Bearings 4 04-17-2007 08:10 PM
Lug Nut Size?? Steve Heywood 1997 -2001 Excella 3 08-16-2005 01:24 PM
Lug Nut Size AYRSTRM2 Axles 0 08-17-2004 01:27 PM
