Old 07-14-2008, 06:39 AM   #1
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
what rims for a 72 tradewind?
Hi,
Being very much a newbie to the airstream world need some advice. I think we have found our airstream but it's going to need new rims. Hubby want to know if the bolt pattern is the same as any truck, ford, chevy dodge. Or are they breed specific and are only made specifically for an airstream.
Thanks for any help.
Annette
bullydogsmom is offline   Reply With Quote
Old 07-14-2008, 06:52 AM   #2
Originally Posted by bullydogsmom View Post
Hi,
Annette
The correct wheels are 15 inch, zero offset 6 holes on a 5 1/2 bolt center.
They "ARE NOT" Ford and Chevy wheels, since they must have a minimum of a 2600 pound rating.
Ford and Chevy wheels fall way short of that weight rating.
Since you have a Tradewind, which is a 25 foot Airstream, you can use Load range "C" tires, or better yet load range "D" tires, with proper air pressure that will assure a better safety margin.
The correct wheels are available from a couple of Airstream parts stocking dealers.
Old 07-14-2008, 07:16 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you go with original wheels you can use the original hubcaps.
In addition to Ford and Chevy, I have heard Jeep rims will fit. I did not know they might not meet specs though as Andy said.
A lot of people go with alloy wheels, which are lighter and allow better brake cooling.
You can also get a 16" wheel with the same bolt pattern and a lower profile tire.
You did not say anything about your tires. Beware of old tires which can look good but are blow outs waiting to happen.
Old 07-14-2008, 07:39 AM   #4
cameront120's Avatar
1972 25' Tradewind
I also have a 72 Tradewind and my wheels were swapped out for alloys made by American Racing, if I remember correctly. The previous owner did this and they look pretty sharp.
North Vancouver, BC
Old 07-14-2008, 07:58 AM   #5
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
There are many trailer specific load specified wheels available. Be sure it is a trailer wheel. In travel, trailer wheels are subjected to side impact forces, (such as a tight turn where the trailer tires might scoot sideways) Wheels for trailers are subjected to many forces that a tow vehicle doesn't encounter.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 07-14-2008, 09:07 AM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Hi,
Annette
You might consider taking the original wheels to a powdercoating firm, and have them restored. As long as they aren't split rims, or mechanically damaged. That way, a Ford baby moon hub cap from a 50's For dpickup will fit, and give you a nice, clean, original look.
Uwe
www.area63productions.com
Old 07-21-2008, 10:20 PM   #7
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
Unless, of course, the tow vehicle is unhooked and being piloted by yours truly.
On a more serious note, even though there are some truck wheels that fit fine and may work out great, you're better off to go with a good trailer specific wheel just to be on the safe side.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-22-2008, 04:54 AM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you don't mind ordering - these folks stock OEM, spoke and chrome wheels at a decent price.
TRAILER PARTS - Low Cost Trailer Supplies
Old 08-25-2008, 06:32 PM   #9
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
Thanks Andy. How wide are these rims? 5, 6. pr 7" thanks again.
biggoofball is offline   Reply With Quote
1966 Caravel: Best New Tires; Old Rims or New Rims??? divotvance Member Introductions 6 08-11-2016 07:43 AM
Help with rims ND Sovereign Wheels, Hubs & Bearings 5 04-21-2008 07:50 PM
1968 Tradewind, I want shiny rims...specs? JeepinAudiophile Wheels, Hubs & Bearings 9 03-22-2005 03:34 PM
New Rims balrgn Wheels, Hubs & Bearings 12 02-17-2005 06:45 AM
Rims Alex Wheels, Hubs & Bearings 7 05-17-2004 07:15 PM
