Old 07-28-2013, 05:53 PM   #1
aquinob's Avatar
Portsmouth , Virginia
What non-airstream hubcaps will fit on 15" rims?
OK, I'm trying to be cheap here. Would really love a set of aluminum rims but havent had much luck finding a set yet. The tires I have are still pretty good, so I'd like to keep using those. So to make the rig look nicer I'd like to find a set of hubcaps that will cover the rims till i can get my aluminum rims. There are lots of sets of older 15" hubcaps on ebay and in junkyards locally for cheap money and they are fairly high quality as well. What I would like to know is what make, model and year hubcaps people have been able to use on the standard rims that come on a 73 airstream? I am aware that besides the diameter of the "teeth" I also have to keep in mind the hub sits a bit proud of the outside surface of the rim. I'm not looking at baby moons right now, really want to cover the whole rims.
Here is what the current rims look like:
Thanks for any suggestions.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 07-28-2013, 06:02 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
These should fit, and ghost what is on the slightly later models:
Single 1 Vintage 1966 Lincoln Continental Hubcaps Wheel Covers 15" Good Caps | eBay
Old 07-28-2013, 06:02 PM   #3
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I had 1957 chevy hub caps on my 1965 Caravel.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 07-28-2013, 06:05 PM   #4
Well Preserved
1993 21' Sovereign
Would that have made it a Chevel?
Old 07-28-2013, 06:15 PM   #5
aquinob's Avatar
Those looked ok and the price was right (25) till I saw that was for just one hubcap. Appreciate the response, just want to find a set a bit cheaper.
Old 07-28-2013, 06:54 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Fifteen-inch wheel covers from a full-size 1970s Cadillac, particularly an Eldorado, should fit with no problem. An example is below:
1973 Cadillac Wheel Covers
The Cadillac center crest on these wheel covers is easy to remove and leaves only two small slits. An Airstream "A" could be riveted to the center to make them even more fitting for an Airstream. I thought of these as they are what came on my '75 Eldorado from the Factory.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-28-2013, 06:59 PM   #7
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Tried to put period Chevy truck hubcaps on my 66 Tradewind only to find that there was not enough dish on the inside to accommodate the Airstream's hubs, so the hubcaps would not go on. Please check this before buying. Even some baby moons are too shallow.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
Old 07-28-2013, 07:22 PM   #8
aquinob's Avatar
Kevin
I saw a few sets of those and thought they would look real nice. Very high quality too especially considering the price. Thanks.
Old 07-28-2013, 07:26 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
80s F150 hubcaps apparently work. The '76 Argosy I recently bought came with a set of these on it.
I don't care for the way they look, but that may be because it make me think of an old pickup instead of a travel trailer.
David
DKB_SATX is online now   Reply With Quote
Old 07-29-2013, 05:18 AM   #10
aquinob's Avatar
I was wondering how those would work with the 6 lugs on the wheel vs the 5 on the cap. Probably not my favorite look either.
