Old 10-27-2011, 06:24 PM   #1
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
What can I take for a 1960 recovery...
In 10 days I'm off to collect a 1960 tandem axle trailer. It needs rims and tires and I have a set on my 1961 Overlander which I think share the same bolt pattern so that's OK, I'll just take them with me.
..Still it's going to be a 2500 Km trip back to base so I want to feel OK about towing her and I don't want new axles just yet as I'll be going with a totally new custom chassis during the shell off process.
I try and plan ahead and have booked the new purchase in with a shop near the pick up location but thought it can't hurt to be prepared with bearings and brake shoes etc just so I can get out of town without too much of a delay. I don't have any experience with Vintage axles, bearings and brakes as I had them updated on the Overlander before I even picked her up. So I guess I'm really asking if anyone would know part numbers or descriptions for the bearings, shoes etc maybe even "bearing buddies" that I could take down? Maybe they're such a standard part that I'm over thinking the whole enchilada but figure if I don't ask I'll only find out too late. I don't even know if it's got torsion axles or leaf so any advice would be great!
truckasaurus is offline   Reply With Quote
Old 10-28-2011, 04:58 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I believe a 1960 model will have leaf springs. (Assuming you have the year correct)
You might bring some electrical light bulbs or wiring to make a temp brake lights and turn sig lights. Don't forget electrical brake wiring concerns. The conector may be different than what your vehicle is wired for.
As long as you have good tires, brakes and lights the rest can be addressed at home.
>>>>>>>>>>>>Action
Old 10-28-2011, 05:54 PM   #3
shermybaby's Avatar
1956 26' Cruiser/Overlander
Kennewick , Washington
Images: 13
Send a message via Yahoo to shermybaby
Uhaul sells some magnetic tow lights that you can stick on the rear bumper. They worked great for me. Just needed a few zip ties to hang the cable up to the side of the trailer. And, I had to make mine longer but that was easy. If you are not sure about lighting/wiring they are cheap insurance.
Chief Cook and Bottle Washer
I even sweep out the place...
shermybaby is offline   Reply With Quote
Old 10-28-2011, 06:03 PM   #4
1960 33' Custom
All good info. I have some magnetic tow lights that I used on my Overlander I just need to extend them considerably as they only just stretched the 26' last time. I emailed Jackson Centre for some info on the running gear so hopefully that'll conjure up some specs. Hopefully the leaf springs are good...
Old 10-28-2011, 09:27 PM   #5
x
XXXX , XXXX
Duct tape and wire to close and bind shut any windows doors etc so you don't lose them. A bungee to keep the door from flying open.
A 60 will be leaf springs.
wasagachris is offline   Reply With Quote
Old 11-02-2011, 02:04 PM   #6
Pack the bearings and use some NEW grease seals.
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
Boris :: 1960 Airstream Caravel Mel Airstream Registry Discussions 0 08-19-2011 08:30 AM
1960 33' custom, railroad bunkhouse ? trailer_tras Member Introductions 11 06-03-2011 02:06 PM
Coolant recovery tank for 1992 300LE ... ? Silver City Classic Motorhomes 3 05-01-2011 07:04 PM
