Old 02-12-2008, 10:55 AM   #1
sound-silver's Avatar
1978 29' Ambassador
2004 25' International CCD
Moab , Utah
We need a spare. What wheel spec?
When I bought our 04 25' International I was aware that it was missing a spare tire. Been pushing the luck these past few months.
Anyhow, does anyone know what the bolt pattern spec would be so I can go into a chain tire store and get a rim?
It's not where you are, but your reason for being there.
sound-silver is offline   Reply With Quote
Old 02-12-2008, 11:24 AM   #2
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi,
Best way is take the trailer and have them mach it. The other way is take one wheel off and have them mach it. That is what I did.
Regards from Russell in sunny and warm Tucson Az.
RUSSELL is offline   Reply With Quote
Old 02-12-2008, 12:02 PM   #3
1978 29' Ambassador
Moab , Utah
Yeah I think you are right on that one Russel. Thanks. The best thing to do is take one down to Big O or Les Schwab. More work for me. Or, maybe less if I got a wrong fit
We have only made it down to Sedona so far. Seeing that you are in good ol Tucson is a reminder that we need to mosey in that southerly direction.
Old 02-12-2008, 01:33 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
6X15X5.5 at a 2600lbs load rating will do. I got mine at a local horse trailer/contractor trailer supply place. Cost about $35 and were new, out of the box. I repainted them because the factory paint was thin.
6 = number of lugnuts
15 = 15 inch rim
5.5 = bolt pattern center to center
Please, correct me if I am wrong but I believe that is the breakdown of the numbers. The 2600lb rated rims were a stopper for many parts houses - but once I went to a dealer who knew what I wanted it was simple.
Additionally - I think you want a 0 (ZERO) offset rim but mine were a -.5 inch offset and were no problem.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 02-13-2008, 07:40 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
That is the correct data for the wheel.
If at all possible match the spare tire to the others. You will get a better fit. Same size different manufacture can be tires that are different outter circumference. And with short term "spare" use that may not matter much either. It's just if you want to rotate the spare in with the rest of the tires then you may be taking the chance in matching.
>>>>>>>>>>>>>>Action
Old 02-13-2008, 08:36 PM   #6
bobkelly's Avatar
Whittier, California , Depoe Bay, Oregon
Don't forget to specify the width of the rim in addition to the rest and match the existing tire size for the spare. Any easy way to get it all right the first time is to buy it from your A/S dealer.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Wheel for Spare Tire azflycaster Wheels, Hubs & Bearings 2 11-05-2006 10:22 AM
Need spare tire and wheel Dan33764 Tires 17 06-19-2006 10:41 PM
Need spare wheel! AJr. Wheels, Hubs & Bearings 15 03-11-2006 07:59 PM
Need a new tire/wheel for spare. tenrsingr Wheels, Hubs & Bearings 10 02-06-2005 08:58 AM
