Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 08-27-2008, 09:32 PM   #1
cosmotini
cosmotini's Avatar
Profile:  2008 27' International CCD FB
Highland , Illinois
Images: 83
Valve stems and TPMS
I was washing our trailer this weekend when I noticed that the Pressure-Pro TPMS had made marks on each of the trailer's wheels. Today, I took it to a local tire shop and had them switch out the rubber valve stems with metal ones. I was happy with the amount they charged. All 4 for $21.50.
Another nice thing I found was that all of the wheels had been balanced. There are weights on the back side of each wheel. The installer made sure he did not move the tire on the wheel. He deflated it, broke the bead, removed the old valve stem and then installed the new one.
I'll have to try to rub out the mark on the wheel but I'm thinking it will become part of the trailer's "character".
Name:	DSC_0231 (Large).JPG
ID:	66454  Click image for larger version
Name:	DSC_0233 (Large).JPG
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 08-27-2008, 09:44 PM   #2
2airishuman
2airishuman's Avatar
Profile:
good info cosmotini!
clearly the monitoring heads are heavy enough to move the rubber stems...
richL had a rubber stem failure recently, that he attributed to aging,
but it may have been precipitated by the monitor nubs.
good of the tire shop to do the balance too!
a metal stem and monitor head clearly alter balance a tad.
i'm still holding out for tpms that go INSIDE the tire at the stem, like some oem versions.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 08-27-2008, 10:01 PM   #3
2dabeach
2dabeach's Avatar
Profile:  2007 25' Safari FB SE
North/East , New Jersey
Thanks for the information. I've had them on my trailer for 8 mos/3,300 miles and have not yet noticed a problem. Will definitly get metal stems before heading south for the winter.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
WBCCI # 8459
2dabeach is offline   Reply With Quote
Old 08-28-2008, 12:05 AM   #4
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Metal or rubber valve stems?
Hi, I was wondering about Airstream useing rubber valve stems on their trailers; My trailer came with metal valve stems, but some others, same model year as mine [actually same year, same model, same wheels, and same size trailer.] were made with rubber valve stems installed. Was this random or a dated production change?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
New Tire Problem Chinese valve stems HowieE Tires 23 09-05-2008 11:20 AM
Valve Stems azflycaster Wheels 1 05-29-2008 08:17 AM
Metal valve stems jcanavera Tires 7 10-31-2007 12:12 PM
Tire Valve Stems Airperson Tires 10 09-22-2007 08:09 AM
Valve Stems LKappenman Wheels 5 08-08-2002 09:34 AM
test
