Old 05-20-2002, 08:38 AM   #1
Finally Retired
Valve Stems
We are getting ready for a trip to South Dakota and had the tires checked for proper even pressure. Seems when they put the wheel liners on they should have put extenders on the valve stems. They were worn about a third through. He couldn't even reach them to check the air One more thing to keep a check on.
LKappenman is offline   Reply With Quote
Old 06-22-2002, 02:16 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Valve stems
Good point~
Also might add this info..last fall I had 4 new tires(245X75X16 E )installed on my Burb. A few weeks later, I was getting ready to leave for a trip..Notice my right rear was down quite abit..Drove over to my local tire shop and, found out that they had installed the wrong valve stem in the wheel..It was one for passenger tires and, at 80 lb of pressure would've blown out. They changed all valves ~ to spec.~ You just never can tell these days...
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-03-2002, 10:34 AM   #3
gwsullivan's Avatar
valve stems
I attended a seminar at the North American RV Rally and Bob Livingston warned about rubber valve stems. They are only rated to 65 psi and the higher load range tires call for 80-85 psi. He said to make sure the valve stems are the metal type. There were some real horror stories by people who bought new tires that were installed with the rubber valve stems.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 07-03-2002, 12:05 PM   #4
1984 29' Sovereign
Savannah , Missouri
Red face valve stems
So true Jerry...I was one of the lucky ones..I had a great tire person..who I should've gone to in the first place..
Now, I do~~!!
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 08-08-2002, 05:34 AM   #5
fdx753's Avatar
2004 39' Land Yacht 390 XL 396
Memphis , Tennessee
valve stems
I just checked out my valve stems. They are rubber. These are on my new 2002 Safari. Apparently they were put on by Airtream at the factory. The tires are Goodyear Marathons ST205175R15's.
The Max Press. Rating is 65psi. Should I replace the stems?
Brian
WBCCI #5167
2004 Land Yacht XL396
2005 GMC Sierra
fdx753 is offline   Reply With Quote
Old 08-08-2002, 08:34 AM   #6
gwsullivan's Avatar
Brian, My understanding is that the rubber valve stems are okay for tires rated to 65psi. The metal type are required for tires rated over 65psi. You should be okay.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Repacing blackwater dump valve Rick Alston Waste Systems, Tanks & Totes 3 02-03-2004 03:20 PM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
Valve stem failure on '02 Bambi dtbw Wheels, Hubs & Bearings 12 10-25-2003 10:17 AM
