Old 05-08-2015, 11:16 AM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Valve stem size?
While shopping for metal valve stems I see that they come in different hole sizes. What size are the stem holes for Airstream 14 inch stock aluminum wheels used on the 2006 Safari 23?
MICHAEL
Old 05-08-2015, 12:24 PM   #2
Zil
egg harbor city , South Jersey
I have only seen two sizes on consumer tires. 1/2 or 5/8. Any experienced tire guy can look at the mounted rim and determine the size.
Zil is offline   Reply With Quote
Old 05-08-2015, 05:17 PM   #3
AWCHIEF's Avatar
Images: 33
Zil, thank you.
I was going to pre order the stems, guess I will drag the trailer over to my tire shop and let them deal with it tomorrow morning. I use the TPS tire monitors and after talking to them discovered that all metal stems are strongly recommended.
MICHAEL
Old 05-08-2015, 05:36 PM   #4
1976 31' Sovereign
Oswego , Illinois
I agree metal stems strongly recommended. I use them on all equipment, trailers, trucks etc. I only use rubber stems on psgr. car
Old 05-08-2015, 06:51 PM   #5
2016 30' Classic
Erie , Colorado
Michael, Have them install the metal valves, mount the TST sensor, and then have them spin balance the tires. They will need to add what was described by the Discount Tire guy that did mine last week, a "surprising" amount of weights. They did it on the inside so nothing shows. Also take a look at the lug nuts. If they are a nut that has a chrome cover on them consider replacing them with solid lug nuts. Anecdotal stories about the chrome cover working itself off and then the lug nut itself is a non standard size and you may not be able to get it off when needed.
My total last week at Discount Tire was $30 for the stems and balance. 24 lug nuts for $60. The guys at DT just rock in my book. Only place I use for tires and tire service. Asked them if they would do a rotation at some point and it was a smile and bring it on in. Great customer service.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 05-08-2015, 07:26 PM   #6
AWCHIEF's Avatar
Images: 33
Gary, thank you. I will have them do that. I recently replaced all the lug nuts with McGards.
MICHAEL
2003 safari 25' SS Moen shower valve stem problems brad_casie Fresh Water Systems 9 01-26-2017 06:25 PM
Replacement cartridge valve stem for my Moen shower, Help???? jerrodwong Plumbing - Systems & Fixtures 4 09-10-2006 08:42 PM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
Valve stem failure on '02 Bambi dtbw Wheels, Hubs & Bearings 12 10-25-2003 10:17 AM
Valve stem Craig Wheels, Hubs & Bearings 1 08-04-2003 05:34 PM
