Old 08-04-2003, 05:37 PM   #1
1962 19' Globetrotter
2001 31' Excella
Valve stem
I had a tire go flat on me due what seems to be a bad valve stem. Went to a local tire shop and they removed the tire to find a tube inside the tire (which was split). They told me that the tire could be used without the tube, however they didn't carry a valve stem large enough for the rim. Wend to another tire shop and was told the same thing...
Any suggestions??
Craig
Craig is offline   Reply With Quote
Old 08-04-2003, 06:34 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
If you have the Alumimum rims you may need to get a bolt in valve stem. It is steel, usally chromed. The base is flanged with a nice thick washer. There is a jam nut that threads on from the outside. Most of the custom rim shops or heavy duty truck tire shops will have them. I have even found them at Autozone.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 03:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 09:45 AM
Repacing blackwater dump valve Rick Alston Waste Systems, Tanks & Totes 3 02-03-2004 04:20 PM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 09:40 AM
Valve stem failure on '02 Bambi dtbw Wheels, Hubs & Bearings 12 10-25-2003 11:17 AM
