09-20-2012, 10:11 PM
1992 29' Excella
Virginia Beach
, Virginia
Using an IR Thermal Gun for Hub Temps
I've seen mention of using IR Thermal guns to check wheel hubs and tires temps when on the road. I have not seen any mention of what those temps should look like.
Can someone explain to this newbie what exactly I should be looking for temp wise when using an IR thermal gun?
Pete
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
09-20-2012, 10:30 PM
Alamo Heights
I have no idea how normal this is, but over the course of a year towing on the Carlisle Radial Trail ST tires that came with my trailer from the PO, the normal tire temperature just after stopping was generally 15-20 degrees F above ambient air temperature. This is on trips starting in North Texas, often in really hot temperatures, but I have taken a few trips in pleasant temperatures as well.
I haven't towed enough with the new Michelins to know if they behave differently... ask me again when I get home from the Balloon Fiesta in mid October.
— David
09-20-2012, 10:44 PM
1992 29' Excella
Virginia Beach
, Virginia
Thanks, that's helpful. Balloon Fiesta! Now I'm jealous. I hope it's a wonderful trip.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
09-20-2012, 10:52 PM
Salem
, Oregon
Hi, my trailer has wheel center caps [hub caps] so I can't get a hub reading. The few times that I checked my tires, they were around 120 degrees. A little hotter on the sunny side.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
09-21-2012, 06:02 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I just finished the Blue Ridge Parkway with ambient temps in the mid 80's. My wheel hubs were generally in the 96-100 range.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
09-21-2012, 07:25 AM
Central
, Mississippi
I shoot the sidewalls and the lug nuts (I also have center caps). The main thing I look for is 'differences' that may be a heads up to a problem.
09-21-2012, 09:30 AM
1978 31' Sovereign
Tampa
Nailed it. As long as all four wheels/tires are within a few degrees of each other, you're fairly safe. It's when one is 15-20 degrees higher that you have a concern.
09-21-2012, 10:18 AM
2002 25' Safari
Fountain Inn
, South Carolina
This is my same approach for using the IR gun.
Bud
09-24-2012, 11:22 AM
1993 30' Excella
Lakeland
Hot hot hot
Pete
That's a good carribean song but not good for tires or hubs. I just towed back from Florida and found at 95 degrees towing between 60 and 65 my tires ran around 115-120 degrees but I discovered my left rear drum was 136, ding ding ding . You can shoot the hub next to the center cap, heat travels nicely on brake drums. It ran cooler each stop so I thought maybeeee the brake was adjusted to tight when they were packed in Cape Cod last year, fat chance, when it was pulled up north the bearing was tanish not silver, not good. New bearings all the way around for me.
09-24-2012, 11:24 AM
1993 30' Excella
Lakeland
Oh by the way it's a great tool to see if your double axle trailer is running level or more on one axle making the tire temps different, or if the air pressure is lower on one tire (it'll run hotter).
09-27-2012, 09:41 PM
1992 29' Excella
Virginia Beach
, Virginia
Thanks everyone, I appreciate the input. I think I have a pretty good idea now of how to properly use and interpret the IR gun readings.
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
09-27-2012, 09:49 PM
1993 30' Excella
Lakeland
I just had the bearings replaced on all four wheels and although only one was running hotter than the rest all had a brown tint indicating they were running a little hot or getting ready to wear out. The sad part is I had a wheel pulled in Florida to check if the PO really did have them lubed and Bates RV said oh they are fine, only 1000 miles later they're not?
09-27-2012, 10:05 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Pete
Thanks for asking the question. It is amazing what I have been able to learn on this forum. I really appreciate the input.
Dan
09-28-2012, 05:12 AM
1978 31' Sovereign
Tampa
I wouldn't trust anything anyone said there. Just my personal biased opinion about the place.
09-28-2012, 07:33 AM
2005 30' Classic
Burlington
, Ontario
Reminds me of buying a used trailer from a dealer some years ago and paying extra to have the bearings inspected and repacked so I would be confident all was well.
A year later, I decided to pull the wheels and repack them and found that in every wheel the grease was hard and caked and the rollers were starting to spall off little bits of metal!
On the one hand I was happy to catch things (just) in time, but on the other hand it lowered my faith in humanity a bit. I'm sure those bearings had never been serviced since the trailer was new.
You'd think I would have learned my lesson, but more recently when we bought our present Airstream from an Airstream dealer (no longer in business I don't believe) I again paid extra to have the bearings repacked before picking up the tariler.
When I picked it up and reviewed the various invoices, there was one for the repack, but no charge for new grease seals.
When I questioned this I was told "We didn't need to change them."
Makes me suspicious!
I generally prefer to do my own repacks!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
09-29-2012, 09:19 AM
1993 30' Excella
Lakeland
HOTEL Bates
If they changed their Service and Parts Managers (two clueless girls) it may have improved. I made an appt. for Jan 5th a month earlier to check my awning and wheel bearings since I just got the trailer and when I arrived the S/Mgr said oh we can't help you today, after coming from Naples I was a little miffed. They sent a guy out who came from Lazy Days RV and he didn't have a clue, then I asked is the rig set up right with the weight bars and they sent another guy out who said drive it and see how you feel (it was to high, needed a longer shank), dangerous condition. I'm a little picky being an ex-Mercedes factory guy but this store needs serious help, front and back.
10-03-2012, 07:49 PM
1978 31' Sovereign
Tampa
I can't tell you how disgusted I am with them time and time again. Unfortunately, I need them more than they need me. Total bozos. I haven't ever found one person to be helpful there. The last time I was there (about a month ago) I told myself I'd never step foot back on the premises.
10-04-2012, 09:45 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
I use the IR sensor pretty much every time I stop - as a part of my normal walk-around. I just look for differences. I also check to be everything is secure (even though I know it is).
Glad to have met you at the rally, Pete and Dan. See you on the road. Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
