Old 05-21-2019, 01:57 PM   #15
blingtin's Avatar
2019 26' Flying Cloud
Roanoke , Texas
Are there ANY negatives to making the change?
blingtin is offline   Reply With Quote
Old 05-21-2019, 02:30 PM   #16
2007 27' International CCD FB
San Diego , California
Yes.
CONS:
- Cost would be a primary negative. Both procuring new wheels and incrementally more expensive tires for 16" as opposed to 15".
- Ride quality. Generally larger wheels result in less tire sidewall. Yet the tire size also has gone up. So this may be a wash but it could again be incrementally worse. There is an opportunity to upsize 15" tires too (225/75r15) and gain more sidewall overall and better ride quality.
The 16" upgrade was driven by a period of time where there were a dearth of good 15" tire choices. The market has since changed and there are many great 15" tires to be had.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 05-21-2019, 02:57 PM   #17
r carl's Avatar
Lin , Ne
I would like to look at a list of many great 15" tires to be had.
Old 05-21-2019, 09:25 PM   #18
2017 30' International
Clifton , Virginia
Also swapped to the 16s
Like many, I read dozens and dozens of negative reports on the 15 GYMs, and an equal number of positive reports. So many in fact that I was going to keep the 15s and be happy with them. Until I talked with my dad. He spent 40+ years as an industrial engineer and many of the applications he developed were mounted on an integral trailer. I asked as an, oh, by the way, have you ever used Goodyear GYMs on anything you worked on? Without prompting he said something to the effect, oh, yea, I know the GYMs, most worthless tire weve ever used. Based on that endorsement, I made the change to the 16s on my 30 Serenity.
Im sure this anecdotal reason for changing wheels will meet with some derision, and YMMV, but Im happy with the change. Now I have 4x15 aluminum and 1x15 steel spare rim taking up space in my garage.
Escape_Plan is offline   Reply With Quote
Old 05-29-2019, 05:06 AM   #19
Cranston , RI
Triple axle
Can this be done on a triple axle?
Hight is offline   Reply With Quote
Old 05-30-2019, 04:35 AM   #20
2000 30' Excella
Toledo , Ohio
wheels
Goodyear now has a ST Tire made in USA called Endurance in both 15" and 16" it is a high speed rated tire
woodfox45 is offline   Reply With Quote
Upgraded Tires and Rims RMB Tires 13 01-10-2013 05:49 PM
upgraded from 14" GYM to 15" LT tvoneicken Tires 16 10-16-2012 09:22 AM
From 14" wheels to 16" wheels Air Cruiser Wheels, Hubs & Bearings 24 09-16-2011 07:18 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
