Old 03-20-2008, 11:43 AM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Truck Wheels on A/S
I am looking at the Eagle Alloy wheel 0589-7766 and the MB 72 wheels below that are Truck wheels. Both come in a 16" 6-5.5 bolt pattern with a 4.25 bore. The weight rating are in excess of 2600 lbs. Is there a problem in using truck tires on the A/S with the Goodrich commercial T/A tires.
Eagle Alloy Wheels Series 058
MB Wheels - 72
The other option is below which is a trailer wheel
http://www.trailertiresandwheels.net...product/AW1603
Thanks Don
adonh is offline   Reply With Quote
Old 03-21-2008, 05:53 PM   #2
adonh's Avatar
1976 31' Sovereign
Let me rephrase this. The top two wheels listed are advertised as "truck" wheels. The bottom listed wheel is described as a "trailer" wheel. Is there a material difference that should be considered?
Don
Old 03-21-2008, 07:25 PM   #3
1984 31' Excella
Norfolk , Virginia
Images: 11
Wheels
adonh
According to what I have read and been told some "trailer" aluminum wheels have steel inserts in them. This was done because of severe weight and overpressured impact wrenches.
Others have gone to the Eagle alloy wheel before me and have had no problems.
Just make sure the weight rating of the wheel (3000 lbs+) and the back set and offset are the same as the original steel trailer wheel.
Beginner
Beginner is offline   Reply With Quote
Old 03-21-2008, 08:31 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
As long as the weight rating, width, and offset are correct, you can use truck wheels on your trailer. I am not so sure about the Goodrich Commercial T/A's, aren't they 10 ply rated?
Old 03-22-2008, 06:32 AM   #5
1984 31' Excella
Norfolk , Virginia
Images: 11
Truck Wheels
Finally got some local tire dealerships to talk with me due to mutual friends. When assured I had a brain and was not a lawyer, information flowed freely, the ones I talked to were familiar with Airstreams and their special needs.
INFLATION: It seems that on the vintage units tire pressure was recommended, such as 45 PSI for the 31 foot units. 8 ply 7.00-15 tires were used. Their max pressure was 65 PSI. The sidewalls had to be doing some flexing. Also Interstates highways and 65 and 70 mph speed limits have been with us since the early 60s. We all know that if you over inflate a tire the center will wear out and if you under inflate a tire the sholders will wear out. I don"t remember the "seasoned" airstream owners complaining about tire failures as we do.
I have tried to get BG Goodrich to sent me an inflation chart for the Commercial T/A twice, but I keep receiving inflation charts for Michelins.
The inflation charts list the following information for RVs: A LT225/75R16 inflated to 65 PSI will carry a load of 2335 lbs.. A Pressure of 60 PSI will carry a load of 2190 lbs.. This goes all the way down to 35 PSI and 1500 lbs..
What is to be surmised from this information?
1. Michelin/Goodyear tires do not require max inflation to be reliable, You can run lower pressures as long as the pressures you run are on the chart AND ARE HIGH ENOUGH TO CARRY THE LOAD YOU HAVE ON THE TIRE. Michelin states by the information in their chart that you do not have to inflate their tires to max pressure to get them to survive the journey. This is reinforced by the older units recommending a less than max pressure for their 8 ply (Load Range D) LT tires that used to be standard on the vintage units. As long as you run the appropriate lower pressures on the E tire you will get the softer ride and because of the different construction methods/rubber compounds the tire should not come apart. I run 60 psi last year with no problems and with no noticable temperature rise. According to the CAT scale I have 1700 lbs max on each tire. I'm thinking of dropping to 55 psi.
2. If you have to run a tire at max (rock hard) pressure to stop failures reguardless of load on the tire, maybe its time to change tires.
All this being said both dealers, both local one Goodyear, one Michelin/Firestone-Bridgstone laughed when I brought up the ST tires.
Both try to steer trusted customers to the LT tires.
Bottom line:
***Its ok to put the E rated tire on your trailer just NEVER PUT MORE THAN 65 PSI IN THEM. Find out how much weight is on each tire and inflate them accordingly.
In my case, 55 psi represents a 17% weight safety margin.
Beginner
Old 03-22-2008, 07:03 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
MB Wheels - 72
Aluminum Trailer Wheel Style: SERIES #03 Size: 16 x 7 Bolt Pattern: 6 x 5.5 Bore Size: 4.25 Load Rating: 3200 lbs @ 80 PSI Offset: -8mm
Thanks Don
Don,
Myself and others are using the BFG Commercial T/As with much success. Try them...............you'll like them!
Old 03-22-2008, 07:49 AM   #7
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
Offset/weight rating
All three wheel choices in a 16" size seem to be appropriate for trailering.
It seems that all three have the requirement for the minimum weight rating for a tandem axle Airstream. ( 2600lbs)
The MB wheel has an offset of -16mm, which means it's center line runs about 5/8in closer to the inside of the hub. It is a 16x7in wheel, 1in wider than the original wheel.
The Eagle wheel is also a 16x7, with a +8mm offset, meaning the tire's center line will ride 8mm ( about 5/16in) wider than a zero offset wheel.
The ttw.net alloy wheel has a negative ( -8mm) offset.
Measure carefully, to make sure that there is enough tire clearance.
Changing wheels and tires on an Airstream with well worn axles can be a challenge, because the hub is much farther up inside the wheel well.
Area63 is offline   Reply With Quote
Old 03-22-2008, 08:09 AM   #8
1976 25' Caravanner
Campton , New Hampshire
Not to start a wheel war , just an explaination. Why is it repeatedly said that trailer wheels must be min of 2600# rated when many original tires were not near that?
ticki2 is offline   Reply With Quote
Old 03-22-2008, 08:27 AM   #9
adonh's Avatar
1976 31' Sovereign
The steel wheels on my 1976 31 ' A/S are original equipment. I know they are 15, 6 lug on 5.5 center with a 4.25 bore size.
What is the offset on these original wheels. Are they 6" or 7" wide.
Don
Old 03-22-2008, 08:44 AM   #10
Area 63 Productions
Orange , California
My best explanation is that Airstream claims that their trailers can be driven on 3 wheels, should one of the double axle's tires go flat.
That would set more load on a single wheel.
Or, there might be a certain beneficial engeneering requirement on a 2600lb rated wheel over a passenger car wheel.
Uwe
www.area63productions.com
Old 03-22-2008, 08:45 AM   #11
Area 63 Productions
Orange , California
Don
They should be 6in wide, with zero offset. That is if they are original.
Uwe
Old 03-22-2008, 08:54 AM   #12
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Offset/Back-spacing explained: http://www.airforums.com/forums/f465...tml#post406899
So Long!
Bob Thompson is offline   Reply With Quote
Old 03-22-2008, 09:18 AM   #13
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
weight rating that high has lots to do with the dynamic loads versus the static loads. If your trailer weighed 4000 pounds and had 4 wheels with tires rated at 1500 pounds each, the static load would would be 1000 on each tire and wheel. In motion the load will increase and decrease from that 1000 per wheel. Because roads are not all flat and straight.
You will actually make turns and might drive over a pot hole or two. All of the running gear components need to survive an event like that or the towing experience stops. 2600 #'s may be excessive and it is a capacity that will not let you down when you have your trailer in service. Also know that this same logic does not apply to all running gear components.
>>>>>>>>Action
Old 03-22-2008, 09:53 AM   #14
1976 25' Caravanner
>>>>>>>>Action
I understand that logic , but what good would it do if the tire was not equally rated ?
Too much truck? gowyn Tow Vehicles 23 08-19-2007 08:34 PM
New HD Truck Shootout! BillTex Tow Vehicles 27 08-14-2007 09:58 AM
You can never have to much truck.... wasafari Tow Vehicles 7 06-14-2007 11:27 AM
For old Truck enthusiasts ALANSD Off Topic Forum 33 11-27-2006 10:08 AM
Changes in HD Truck Market TIMEMACHINE Tow Vehicles 52 10-28-2006 10:28 PM
