Old 08-04-2015, 07:33 PM   #1
2007 28' Classic
Ivanhoe , Virginia
Smile Tpms
I have new Airstream coming next month and was wondering if anyone knows if the tires have metal valve stems? I want to use the TPMS ' off my old rig and they need to go on metal valve stems.
Thanks in advance,
Senioryakker
senioryakker is offline   Reply With Quote
Old 08-04-2015, 08:21 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
No, they will come with cheap rubber stems.
MICHAEL
Old 08-05-2015, 05:47 AM   #3
2007 28' Classic
Ivanhoe , Virginia
Thanks for the info.
Old 08-05-2015, 07:00 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The original Airstream Good Year Marathon 15" ST ties have been so unreliable and prone to blowouts, many of us have changed to Michelin 16" LTX tires and Sendel 16" wheels (standard on Eddie Bauer and new Classic Airstreams).
This is better money spent than TPMS as a first purchase. We put on four Michelins and new wheels for $1500, sold the originals for $500, and kept the original spare tire for the unlikely event we will need it.
The reasoning here is the GYM's have a high blowout rate, the Michelins have been virtually blowout-free. A sudden blowout is likely to damage your wheel well and nearby equipment. TPMS may warn you of impending failure, or it may only warn you that failure (and damage) just happened.
For extended travel, especially in hot weather, the first upgrade ought to be better tires. Then consider a TPMS which is much, much less likely to activate from tire failure advising you a tire has blown and damaged your Airstream.
Doug and Cheryl
Old 08-05-2015, 07:32 AM   #5
AWCHIEF's Avatar
Images: 33
Cheryl, way to go off topic.
MICHAEL
Old 08-05-2015, 07:46 AM   #6
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Thanks in advance,
Senioryakker
I think the best one to answer that question is where the AS is coming from. All they have to do is look at it and tell you as they do!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-05-2015, 08:27 AM   #7
Cumming , Georgia
Thanks in advance,
Senioryakker
What system do you have?
mbenson1234 is offline   Reply With Quote
Old 08-06-2015, 06:20 AM   #8
2007 28' Classic
Ivanhoe , Virginia
Don't recall the brand name, but have been using on my fifth wheel and dually. Seems to work as advertised, needs to be recalibrated, and is a pain to remove to adjust air pressures, but it is what it is.
Old 08-06-2015, 11:06 AM   #9
Cumming , Georgia
Would a Flow Through Sensor help you so when you add air you do not have to remove the sensor? let me know
Mike Benson
TST
Old 08-06-2015, 12:32 PM   #10
AWCHIEF's Avatar
Images: 33
Mike I have your system with the standard sensors. Would there be a charge to swap for flow thru sensors?
MICHAEL
Old 08-07-2015, 11:22 AM   #11
Cumming , Georgia
Michael,
How long have you had them?
Old 08-08-2015, 05:49 AM   #12
AWCHIEF's Avatar
Images: 33
Originally Posted by mbenson1234 View Post
Michael,
Mid April this year.
MICHAEL
Old 08-08-2015, 06:12 AM   #13
2007 28' Classic
Ivanhoe , Virginia
Tpms
Mike,
Found the box, my system is the TST.
Old 08-10-2015, 08:52 AM   #14
Cumming , Georgia
I can give you a large discount to trade up to the 507FT. Call me when you can 770-889-9102 Thanks,
Mike Benson
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Thoughts on TPMS mwells4654 Tires 33 11-02-2010 04:20 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
