08-23-2017, 08:44 PM
#41
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
It's actually not bad to use a breaker bar for torquing lug nuts WITH a digital torque adapter. Actually that way using a cheater pipe is no problem and it doesn't use as much space as a torque wrench and breaker bar.
https://www.harborfreight.com/12-in-...ter-68283.html
I did look up that 'HarborFreight website, and :
TWENTY BUCKS for a half-inch drive torque wrench???? YOIKS!
In Canada, a good torque wrench can cost an average of $50-70, and at Canadian Tire, one can spend up to $140 for one.
08-23-2017, 08:47 PM
#42
1974 27' Overlander
Baltimore
, Maryland
A *good* torque wrench costs that much here, too...
08-23-2017, 09:48 PM
#43
1999 34' Excella
Hillsboro
Steel or aluminum wheels?
Our steel actually had worn lug nut seats.. replaced with aluminum..
After 50 miles stopped and checked. Checked again at 150. A couple caused the good quality, click torque wrench to proper torque.. ran to Big Bend .. several hundred miles, checked less often..a couple tightened...fewer each time. Once home, all lugs were at proper torque after 500 miles.
BTW, lug nuts wear out... if you can wiggle before tightening then buy a new one to see if there is a different feel.
Don't overlook poor wheel balance.
Peace and Blessings..
Channing
WBCCI# 30676
08-26-2017, 11:21 PM
#44
Tampa
I've driven for 50 years and never torqued a lug nut or had one fall off. Nor do I know anyone who has.
But I've just purchased a torque wrench from Harbor freight.
Because being OCD is the Airstream way.
However is there a standard size socket for the lug nuts on an Airstream? I'd like to keep a 1/2" drive socket handy.
08-27-2017, 12:10 AM
#45
2007 22' International CCD
Corona
As a long time owner of Japanese and Swedish cars, I have always torqued lug nuts. Overtorquing lug nuts was a good way to warp brake drums and rotors on those cars.. and a tire-buster that even went near my cars with a rattle wrench to put wheels on got told off right quick.
08-27-2017, 05:11 AM
#46
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
+1
Old Fart=Old School
Personal priority....clean mating surfaces, clean & dry threads.
Frequent OTR checking.
08-27-2017, 05:56 AM
#47
2018 27' International
Southeastern MI
, Michigan
When I drove a tow truck the most frequent issue drivers had was wheels coming off after tire changes. I used a long cheater bar but not a torque wrench, never had an issue.
Shops that use impact wrenches sometimes enlarge the holes in steel rims enough that the lug nuts never seat. I always checked 'em before installing.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
08-27-2017, 06:06 AM
#48
2005 30' Safari
Montgomery
Saw a post on Airstream Addicts on Facebook yesterday where a guy's tire came off right at 50 miles after leaving the tire shop. Had a little bit of wheel well damage. Ouch. Thankful I don't have to sort that out. I check torque about 1000 miles or so, though haven't caught anything too out of line.
08-27-2017, 08:28 PM
#49
Blenheim Ontario
, Ontario
HMMM! Says a lot, doesn't it.
08-31-2017, 05:20 AM
#50
2017 28' International
Virginia Beach
, Virginia
I am a relative newbie. I have less than 1,000 miles towing on 3 trips. I torque my lug nuts and check my tire pressure as part of my departure checklist. It takes 5 mins and it's a little more peace of mind. We attended a recent rally and was surprised at how few fellow Airstreamers did not do this. Maybe a lot of experience shows it isn't required as often.
08-31-2017, 05:26 AM
#51
Virginia Beach
, Virginia
That "wiggle" may be the chrome cover over the lug nut. I have a 2017 28' International and have replaced all my factory lug nuts with solid ones.
