Old 02-25-2015, 06:49 AM   #1
2015 30' Flying Cloud
longview , Washington
Question Tires on 15" Rims
Has anyone put Michelin tires on OEM 15" Rims instead of going with 16" Rims?
clipper30 is offline   Reply With Quote
Old 02-25-2015, 07:14 AM   #2
1976 31' Sovereign
Oswego , Illinois
Yes
Old 02-25-2015, 07:35 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yes
Old 02-25-2015, 07:38 AM   #4
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Yes, many have, but probably not too many with a new 30' trailer with an 8,800 gross weight.
If you want to stay with 15" rims, you'll need to find another brand of tire with an appropriate load rating, like Pirelli, Maxxis or Nokian.
Lance
Lance M is offline   Reply With Quote
Old 02-25-2015, 07:45 AM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Putting the Michelin 235/75r15 XL tires on your rig would be ill advised. Derated for your application that's 1964.70lbs per tire or 7,858.80lbs total rating.
Pretty much what Top just said.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 02-25-2015, 08:58 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The tires have to be rated for the gross axle weight. The 15" at 1980 or so load rating might just make it. (or not). I run them on my 25' that has a gaw of 6300 lbs. I have seen the 15" on a 30' from Ontario but I would go with the 16" for that size trailer myself. I thought the 30 ft came with the 16" now? Or are the 16" rims an option? Anyway I think they would be worth it on that size trailer.
Old 02-25-2015, 06:09 PM   #7
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
If I had a big, heavy trailer. I would seriously consider a set of these Goodyear Cargo G26 in 225/70/15. Load range D 2,470lbs of load capacity.
Lance
Old 02-25-2015, 07:57 PM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
One needs to inspect the Airstream provided stock factory wheel for it's load rating and at what pressure is that load rating obtained. The stock GYM ST tires are to be inflated (per the factory label on the street side front of the trailer) to 65psi on the Airstream Trailers.
The Michelin LTX (P) 235/75R15 XL 15" tires have a derated load capacity of 1,985 pounds at 50 psi which equals 7,940 pound load capacity for four tires. That is adequate capacity for axles rated to 3,970 pounds. Thus the 3,800 pound rated axles of the 2014 25', 25FB, 27" and 28" models can be supported. The 30' and 30' bunk have 4,500, pound rated axles and the 15" Michelins are underrated for that job. (Axle data from the 2014 Flying Cloud Parts manual)
The SenDel 16" T03-66655T wheel Airstream has selected for the Eddie Bauer trailers as an option and is now standard on the 31' Classic with a 10,000 pound GVW is rated for 3,580 pounds at 80 psi. The Michelin LT225/75R16/E LTX M/S2 16" tire is rated 2,680 pounds at 80 psi and is the tire Airstream installs.
At the Jackson Center Factory store, that 16" tire and wheel combination is offered for sale in the hallway before reaching the receptionist desk. These can be installed on most 15" wheeled trailers.
Old 02-25-2015, 08:47 PM   #9
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I think this thread is about solutions for 15" tires on a heavy trailer. The 16" option is well documented.
Lance
1966 Caravel: Best New Tires; Old Rims or New Rims??? divotvance Member Introductions 6 08-11-2016 07:43 AM
HELP! with tires, switching to 16" rims. Libo Tires 92 01-12-2014 12:19 PM
16" Rims and Tires on a 2008 23 foot International SONGBIRDS Tires 2 12-06-2013 04:48 PM
Larger tires on 15" rims, 235-75R15LT etc Jammer Tires 2 02-06-2012 01:16 PM
