1978 Argosy Minuet 6.7 Metre
Jensen Beach
Tire rims
I've got a 1978 Argosy 22ft Minuet. Question is about the tire rims. Mine are rusty (superficially) and do not look good. They are I think steel. Should I find someone to clean and paint them or just get new rims? The axle is new from 3 yrs ago. Any ideas?
You can get new black powdercoated Dexstar steel wheels for about $50 from etrailer.com. (other colors may be available)
Spend over $150 and shipping is free.
If you want a custom paint job, go the route Bob suggests.
On our Tradewind, most of the rim is covered with hubcap... so a little Scotch-Brite, phosphoric acid treatment, tapeing and spray paint and they look fine .
If you have riveted wheels, you have additional areas of potential rust damage. My '72 steel wheels lost no air in two years until I started overnighting in the high desert. With the temperature swings came many overnight flats. Eventually noticed that three of the wheels had internal rust bubbles around the rivets. After buying a set of Dexstar wheels I had no more problems.
