Old 02-16-2015, 02:25 PM   #1
2013 30' International
Ottawa , Ontario
Question Tire - Axle Brake Maintenance
I have a three year old AS International. It has approximately 3000 miles under its belt. Question, apart from maintaining tire pressure, checking tires for nails or unusual wear, are there any additional afety measures I should take e.g. rotating tires, packing brakes etc. I am not too mechanically inclined,, so any help would be appreciated. Thank you
sunseeker
I.G.W.
sunseeker is offline   Reply With Quote
Old 02-16-2015, 03:09 PM   #2
dznf0g's Avatar
Oswego , Illinois
I rotate about every 3000 - 5000 miles.
What bearings do you have. Standard bearings should be repacked...some say annually...I would repack every other rotate. I have Nev-r-lube bearings, so I check them for lateral run-out whenever the wheel is in the air...at rotate time, and check their temp with an infra-red thermometer while on the road at fuel stops.
Brakes are checked also whenever the wheel is off (discs). Drums should be checked whenever the bearings are inspected/repacked. Shoe adjustment (non-self-adjusting type) every couple thousand miles.
-Rich-
Old 02-16-2015, 03:38 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Tricky title. I thought you going to say your axle actually had a failure.,
MICHAEL
Tire Maintenance - am I being paranoid? - Part 2 crazie_eddie General Repair Forum 1 10-20-2013 07:00 PM
Tire Maintenance - am I being paranoid? crazie_eddie General Repair Forum 11 10-05-2013 08:10 AM
Tire and axle maintenance AirStream73 Towing, Tow Vehicles & Hitches 1 04-21-2012 10:28 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
16' Bambi Axle/tire/brake upgrade ljmiii Axles 2 02-26-2007 04:46 PM
