Old 04-29-2016, 02:24 AM   #43
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We recently (March 2016) ordered four of the complete Timken bearing sets (both #4 and #17) and ten seals (#441151) for the 10" brakes system used on the 23D and sold on Amazon. They had "Made in USA" on the boxes. The extra seals were is case of installation errors or future service.
Old 04-29-2016, 07:10 AM   #44
Storm Master
Ampman's Avatar
2005 25' Classic
I use Inland Truck parts. They have many locations but are not everywhere. The salesman at the Austin, Tx location told me they were only sourcing the USA made Timkens. When my order came in that's exactly what I got. I'm sure other brands are ok but I will still pay more and go to the trouble to get stuff made in USA. It's the principal of it all to me. I like to think I'm supporting a hard working American keep their job. Maybe they will do the same for my kids one day.
Ampman is offline   Reply With Quote
Old 04-29-2016, 07:31 AM   #45
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I'm not too warm and fuzzy for the SKF brand of bearing. Last fall I had to put unit bearings on the front of our 2002 Grand Cherokee. The SKF bearings were manufactured in Czechoslovakia and one of them did not last 100 miles before it was howling.......
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 04-29-2016, 09:14 AM   #46
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
How long should axle bearings last?
I think SFK is what I found in my Safari while greasing the bearings this week. I was surprised to see Slovakia printed on them, though I could not read all of the letters and numbers. I think these were the original bearings that came with that trailer. They still look good enough that I re-installed them.
I've never had a bearing failure in any of the Airstreams, or any other trailer, that I have owned.
A question to those of you who maintain multiple trailers as your profession:
How long should axle bearings last if well maintained? (20-30 years? 50,000-100,000 miles? As long as the axels lasts?)
Old 04-29-2016, 10:08 AM   #47
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The life of the axle IF the roller bearing is well maintained.
Non-servicable bearings in car have gone 200,000+ miles. It is the servicing or maintence that is the issue. Either lacking in maintence, or improper installation or getting debris in with the bearing during serving.
>>>>>>>>>Action
Old 09-09-2017, 02:51 PM   #48
1981 31' Excella II
Alpharetta , Georgia
I'm looking to do my first bearing service on our 31' 1981 Excella II (dual axel), and having a hell of a time figuring out which seals, bearings, and grease to get (we want the top of the line for it all).
Can anyone point me in the right direction here?
Thanks!
britta315 is offline   Reply With Quote
Old 09-09-2017, 03:40 PM   #49
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Quick packing tip....
If you own a food vacuum sealer you can fill the center if the bearing with grease, put it in a sealer bag then suck out the air.
The grease is drawn into the bearing for s perfect oack every time. Leave a few unopened bearings in the sealer bags... Ready for use on the road should you need one. You never touch the grease!
Old 09-09-2017, 03:44 PM   #50
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
That is a great tip! Just wish I had a vacuum sealer!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 09-09-2017, 03:54 PM   #51
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Harbor freight to the rescue!
Old 09-09-2017, 06:15 PM   #52
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi britta 315. Tapered roller bearings are built to an industry standard. The configuration of the bearings is identified by a universal part number. These part numbers are typically stamped on the ends of the bearing somewhere. Sometimes it takes a magnifier to see it.
Your trailer most likely has 12" drum brakes. When you do the bearing service, the drum is coming off. Then you will have the bearings in hand except for the cups that are pressed into the drum. The cups can be removed by had but it is a bit tricky.
Me, I found it easier to load up my 4 greasy drums with the bearings in a sack and take them to your local trailer supply place. They can more easily use their press to remove the cups in the drum. They most likely have replacement bearings in stock. Timken is a very good manufacturer. Tell the shop you want Timken or equivalent. I'm guessing it will be about $200 a drum for new bearings.
Your old bearings may be perfectly good and just need new grease. That is a cheaper option.
David
Old 09-09-2017, 10:26 PM   #53
PaulnGina's Avatar
Good Ol' , USA
Originally Posted by dbj216 View Post
....... I'm guessing it will be about $200 a drum for new bearings.
David
Did you really mean $200?
I ordered 5 sets of Timken bearings and races from RockAuto, and a race tool, for $135.... made in USA.
http://www.aviontrailers.net/post1186.html#p1186
1987 Avion 34W
Old 09-12-2017, 03:56 AM   #54
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Well, I was guessing. I should have looked up the prices for two bearing sets per wheel times 4.
David
brake parts, timken bearings, gabriel shocks woodmon8 Airstream Classifieds 0 04-17-2015 04:43 AM
Anyone replace MH Front Wheel Bearings? swebster Mechanics Corner - Engines, Transmission & More... 17 06-27-2004 11:55 AM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
Replace Wheel Bearings? Pick Axles 6 02-28-2003 06:30 PM
