Old 09-13-2016, 04:32 PM   #1
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
timken wheel bearing and races prices UP!!
I had put some timken wheel bearings #25580 #LM67048 plus the races #25520 and #LM67010 for a 2005 classics model in the shopping cart.
They other day when i was looking at something in the shopping cart on amazon and noticed an detail that stated the price of the bearings had increased by like 8 bucks or more.
Anyone else see this..??
Seems the price of the US made bearing are starting to raise due to production heading off shore in 2017 I was reading..
might be time to stock up on the US made timkens before they are GONE..
cost now for set of 4,,, 135 bucks..
what is number for double grease seals.. the airstream factory shows 680370-100,, found them at outofdoorsmart odmrv.com 6.75 each. SCORE..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
Timeshare owner/user since '99
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 09-13-2016, 05:13 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Buy your bearings and seals from an auto supply house like Rockauto.
You have to know your products when dealing with Amazon. They wanted $6.00 for a sim card for my phone. They are free at Verizon.
2004 Excursion 4x4
Old 09-13-2016, 05:22 PM   #3
1977 31' Sovereign
2005 30' Safari
North Port , Florida
As Howie said, you just have to know where to buy them. An entire set for my trailer locally is around $50. Stay away from the dealers.
cliffcharb is offline   Reply With Quote
Old 09-13-2016, 05:40 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Happens all the time on Amazon.
I buy all my bearings thru NAPA. Best price and known quality.
MICHAEL
Old 09-13-2016, 06:16 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
With the availability of the world wide web, shopping and price comparison becomes much easier. (Still consumes time)
Knowing a specific part made by a manufacturer and sold through many sources means there is competition. That competition usually means some source may be low today. Just not so much the next day.
Good luck shopping! For AS parts and for everything else.
>>>>>>>>>>>Action
Old 09-14-2016, 01:26 PM   #6
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
[QUOTE=Action;1850376]With the availability of the world wide web, shopping and price comparison becomes much easier. (Still consumes time)
Many online sellers are just drop shippers who do not have the part but order it and have it shipped directly to you. Some can buy wholesale and sell retail and some are buying at retail with and marking it up to sell to you. I bought a Camco 30A male plug on eBay at what seemed to be a good price since it was lower than Walmarts online price with shipping and it came in an Amazon box. I looked on Amazon and it was $2 less with free prime shipping. The eBay seller was a drop shipper who sent it to me as a "gift". It pays to shop around.
rvb is offline   Reply With Quote
Old 09-14-2016, 01:59 PM   #7
Old Sailor
McArthur's Avatar
1983 34' Excella
Victoria , Texas
I follow this forum religiously for the wealth of information I find here. Thanks to everybody for helping to educate a relative "newby".
My first fall project on my '84 Excella 34 footer is to pull off the wheels, one axle at a time, and replace tires, brakes and bearings with races and possibly change out the shocks. I'd like to have the parts on hand when I start so what I'm hoping to find is the part numbers for brake parts and bearings and races so I can order them. If anyone has the part numbers handy I'd sure appreciate getting them.
As far as I can tell, everything underneath is completely original. The torsion arms all have a good positive angle and the trailer tows like a dream. I would bet that since the old tires on it were manufactured in 1994, they were probably the second set installed. The tread on them looks like brand new tires. I think this trailer has very low milage on it.
Thanks in advance,
The Old Sailor
'82 Excella 34' "AlumaLady"
'06 Ram 2500 Lonestar
"Mollie Bug" The Boston Terrier
WBCCI #4456 - Born to Cruise
McArthur is offline   Reply With Quote
Old 09-14-2016, 02:58 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Shocks you will have to get from an Airstream dealer as the only application is Air Stream. No one else will carry those.
There isn't a consumer parts manual with numbers. However the bearings, seals and brake parts are for the most part off the shelf stuff. So obtaining trailer parts locally can be done at a trailer store like McD. http://www.mcdtrailers.com/ Unless someone has messed up, you should not need bearings & races. Some seals may be brake friction parts. The rest is clean, lube and adjust as needed.
Even fast moving auto parts stores (NAPA) may carry seals and bearings.
Or going online after you know what you have can save you a few dollars if you can wait a few days.
I buy and sell a lot of used auto parts from the late 1960s to early 1970s. Ebay is a big player for that. However Amazon and several others are good too.
>>>>>>>>>>>>Action
Old 09-14-2016, 07:34 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Most of the Timken bearings are made in China now.The bearings on Amazon are made in the USA.The only way to tell is look at the print on the bearing.
I personally will not run Chinese Timkens or any Chinese bearings on our Airstream to save $100 or so.
Old 09-15-2016, 07:43 AM   #10
2003 30' Classic
Fresno , California
Try a Bearing Store....Industrial PT
I am retired but used to work in the Industrial Power Transmission business and can tell you that buying Timken Bearings at one of these places will save you money and you are likely to get US made bearings. Timken manufactures off shore as well but most PT houses stay away from foreign markets.
ldireland is offline   Reply With Quote
Old 09-15-2016, 03:03 PM   #11
Moflash's Avatar
This was true 5-10 years ago But not true anymore.Most stock Chinese parts as there is more markup.
Timken wheel bearings Ampman Wheels, Hubs & Bearings 53 09-12-2017 04:56 AM
brake parts, timken bearings, gabriel shocks woodmon8 Airstream Classifieds 0 04-17-2015 05:43 AM
Wheel Bearings/Races & Seals 1958 18' REDSLED88 General Repair Forum 17 03-25-2012 11:03 PM
Gas prices, diesel prices, and crude oil prices Tin Diesel Off Topic Forum 2 02-12-2009 01:41 PM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 08:36 AM
