Old 07-11-2016, 02:49 PM   #1
MarfaTX1965's Avatar
1965 28' Ambassador
Marfa , Texas
The right grease seal for 65 ambassador?
I have 12 in breaks, Is the grease seal that is 3.269(od) x 2.25 (id)the right size? The other size I have found is 2.25(id) x 3.376(od). Thanks for any info.
Safe travels to ya'
WBCCI#6528
MarfaTX1965 is offline   Reply With Quote
Old 07-11-2016, 03:13 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
With that must discrepancy I would measure the drum and spindle with a set of calipers. Once you determine the size you can order them from several auto supply houses at about a 1/3 the cost of a trailer shop.
Try and get a double lipped seal.
2004 Excursion 4x4
Grease seal P/Ns TomW Axles 8 11-10-2012 06:13 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
'57 Grease seal #? 3Ms75Argosy Axles 1 10-13-2008 08:34 AM
grease seal for 2006 Safari SE 25' mistermcfrug General Repair Forum 2 09-06-2007 07:43 AM
Specific Grease Seal Model AirSpleen Axles 4 11-29-2006 01:15 PM
