Old 07-02-2015, 09:37 AM   #57
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
A side note that I neglected to mention regarding the installation of the CM's in my application was that they will only fit one way. One side the ring where all the action happens will interfere with the wheel going on. Simple thing to reverse the CM. I have the Sendel T-03 wheels. Don't know if this is a factor with other wheels. Something tells me this will have no impact on the function of the CM's.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-02-2015, 02:16 PM   #58
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Correct, there is no "rotation direction"... Installing with the "ring" inboard will
Workie jes fyne!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-02-2015, 02:32 PM   #59
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I asked the folks at Centramatic that very question about the ring being in or out. They told me that they worked the same either way.
Brian
SuEllyn & Brian McCabe
Old 07-02-2015, 02:47 PM   #60
Zackybilly1's Avatar
2012 28' International
2009 34' Panamerica
Poplarville , Mississippi
Before putting Centramatics on my Airstreams, I have four GoldWings (3 big Wings & an F6B) that I am using them on (along with TPMS).
In my quest to get proper tire wear on my Wings, I installed suspension upgrades (at significant expense), replaced neck bearings, etc.. It was only after I installed Centramatics did I get the tire life and wear pattern to an acceptable level. I always balance the wheels even though running Centramatics.
Armed with this positive experience, it was a no-brainer to me about using them on the Airstreams when I installed 16" wheels. As mentioned above, your wheels may be balanced but that does nothing for the lack of balance on brake drums, etc..
To me, Centramatics is money well spent, as well as, a TPMS.
Z
Zackybilly1 is offline   Reply With Quote
Old 07-02-2015, 06:17 PM   #61
2016 30' International
Scottsdale , Arizona
Originally Posted by switz View Post
Not all workers at tire centers have been motivated to do the job properly the first time, not realizing they could put someone at risk down the road with their indifferent attitude.
Lou... are you running Centramatics on your new coach? Thumbs up?
DHart is offline   Reply With Quote
Old 07-03-2015, 08:01 AM   #62
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The Michelin LTX (P) 235/75R15 XL tires are mounted on SenDel T03-56545T wheels (15" wheels with 14" drum brake 5 bolt circle) with the Dill 1506-453 TPMS system and Centramatic model 200-221 plates. Tire pressure is set to 44 psi.
These wheels are the same design as on our Classic, just an inch smaller in diameter.
All will be mounted on the trailer before the unit leaves the dealer lot.
Old 10-28-2015, 11:54 AM   #63
2010 27' FB Classic
N/A , Texas
Last trip, one of my trailer wheels threw a weight. I'm now thinking of buying a set of the Centramatics for the trailer and possibly for the TV as well. Of course, I like to buy at the lowest total price. If I purchase them for both vehicles and buy direct online from the manufacture here in TX I have to pay tax and shipping and the regular price for the whole order and that comes to $632.39.
Break down of costs:
Trailer complete set=$199
Truck front= $179.
Truck rear= $189
subtotal= $567
Tax=$35.44
Shipping=$29.95
Grand Total=$632.39
Anyone aware of a supplier selling them for less? Lower prices, free shipping and/or no tax would make my day!
Old 10-28-2015, 01:07 PM   #64
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Bluto, are you close enough to CM mfg to pick them up yourself? That could save you a few bucks.
I haven't found them any cheaper as well.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 10-28-2015, 01:57 PM   #65
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
The Centramatics Thread
Did you try Andy at Inland RV?
http://www.inlandrv.com/catalog/prod...roducts_id=485
$40 each
Silverflames is offline   Reply With Quote
Old 10-29-2015, 09:07 PM   #66
2010 27' FB Classic
N/A , Texas
Sphere Guy, I may just end up doing that if I can't get better pricing.
Silverflames, Ya, but Id have to buy new axles to get that price from Andy. Thanks
but I'm about 20 years away from needing new axles. But it was worth a look!
Old 10-30-2015, 02:36 PM   #67
1969 29' Ambassador
Ahh.. Didn't know that.. Got mine with axles.
Old 11-01-2015, 05:17 PM   #68
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Bluto, that's not that much more than a tire or two.
If you're near Alvarado, TX, it's a first class shop to check alignment on both vehicles. So, if you've also been needing to upgrade truck antiroll bar bushings to poly (factory rubber should be disposed of off showroom floor), stop on in. Order the grease-able Energy Suspension versions beforehand to bring with you.
Old 11-02-2015, 04:56 PM   #69
2010 27' FB Classic
N/A , Texas
Slowmover,
I didn't know they did other stuff to, it's good to know, a good shop is hard to find these days. Just finished a 4000+mile trip a couple of weeks ago. Now I'm starting the check everything and change fluids and filters so of course this thread caught my attention. I see you and others have had some good things to say about Centramatics so they are on my list for a near future purchase.
Old 01-11-2016, 07:35 PM   #70
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Are they available in Canada?
How 'bout other brands that do the same thing?
MelGoddard is offline   Reply With Quote
