Old 05-27-2015, 10:20 AM   #43
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
When I upgraded my running gear last July at JC, I had new 4,500-lb axles with Ner-r-lube hubs, 16" Sendel wheels, Michelin LTX225/75R16(E) tires & Centra-Matics installed. Since then I've put on about 15,000 miles. The only comment I have is that it took about 500 miles (first 25 and then every 100 miles after that) to completely torque the lug nuts. No issues at all.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 05-27-2015, 10:21 AM   #44
Pileus's Avatar
1985 31' Excella
Seguin , Texas
I would avoid purchasing any axle so flimsily made that it can't accommodate Centramatics.
Pileus is offline   Reply With Quote
Old 05-27-2015, 02:44 PM   #45
bwpaint's Avatar
2015 25' FB International
my , house
Originally Posted by switz View Post
Centramatic 300-356 all A plates for 16" rims or 200-221 Special for 15” rims (both sizes are $199.00)
I have Centramatics installed on both the trailer (300-356 all A plates on the 16" SenDel wheels)
When I ordered my set, I ordered the 300-356. I was not aware of the A Plates only suggestion. The B plates have a slight center rise, for additional clearance as needed, per the instructions. Not needed- the plate worked facing in or out. It is about 1/16". Is this going to cause a problem I have not anticipated?
bwpaint is offline   Reply With Quote
Old 05-27-2015, 02:45 PM   #46
2016 30' International
Scottsdale , Arizona
Thank God for the internet so we can have discussions like these and opinions can fly around from every direction.
Hopefully a definitive and concrete (expert) opinion will come of this discussion/exploration!
DHart is offline   Reply With Quote
Old 05-27-2015, 03:09 PM   #47
dznf0g's Avatar
Oswego , Illinois
Probably not....you have inordinately high expectations.....
-Rich-
Old 05-27-2015, 03:49 PM   #48
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
SAE is often cited as a source of expertise. But depending on the issue (WD formula, for example) they can be shown to be wrong. Same thing on this issue: there is no guarantee with or without CM balancers that the axle will avoid problems.
Towing at 72-mph would be another instance of what constitutes best practice. Braking and handling become a problem before this speed, but it hardly keeps some from using that travel speed.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 05-27-2015, 05:16 PM   #49
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Disclaimer - I'm not an expert...
But the Dexter folks aren't hedging their bets here. They do not recommend them in their Nev-r lube axles. To some, their view counts as expert opinion, to others, it's legalese.
Folks make their decisions as they see fit.
Old 05-27-2015, 06:25 PM   #50
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Definition: Expert; 'Ex' is a 'has-been', 'spert' is a 'drip under pressure'
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-27-2015, 06:38 PM   #51
W , New England
Does that mean "formerly a drip under pressure" 😜
Side note - if you don't have William Shatner's album "Has Been" - you don't know what you're missing! No kidding - it's in my top 10.
Back to our regularly scheduled, well balanced (see what I did there?) debate-fest 😄
Old 05-28-2015, 01:22 AM   #52
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Professional and expert used to mean that they knew all about certain items; Now it just means that they get paid for doing what they do.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-28-2015, 01:35 AM   #53
Yep... there are a lot of divergent views expressed on internet forums... and here, just as much.
All one can do is consider a wide variety of viewpoints, consider the sources, and then make up their own mind based on how those other viewpoints interact with their own experience, knowledge, and sensibilities. I almost never trust in what ANY one individual might advise. With overwhelming consensus on a matter, I may be more trusting. Following your "gut" is often is the best choice in many situations. In my life, I've learned that, usually, the gut "just knows." ;-)
Old 06-21-2015, 08:54 AM   #54
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I recently decided to give the centramatics a go. Got a set and put them on last month. The jury's still out on their benefits. I've only had 2 short trips with them and still find a a few drawers open and stuff shifted. I'm not sure what I expected and there are just so many variables to consider. I run my michelin LT's at 80 psi. I just might consider reducing the pressure 5 psi when we go out again. Between a combination of rough roads and non-interstate driving it's difficult to compare but I'm still optimistic and feel confident that they are a plus. Before purchase I called to confirm the application for the ones I selected and found that I had chosen incorrectly. That may explain why the one user above found the mounting to be clumsy and needed to hammer them on. The sales rep I spoke with called centramatic for me and corrected my selection and all fit nicely.
See ya'll on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-01-2015, 09:17 AM   #55
blufishin's Avatar
2015 25' FB Flying Cloud
Wilmington , North Carolina
Hello all......I'm a new owner of a 2015 FC 25 fb. Purchased a TPMS from Hawkshead that required metal valve stems. Had the wheels re-balanced after installing the new stems. The stick-on lead balancing weights fell off the wheels before I even hit the road!! Probably not thoroughly cleaned before they were applied but this got me to worrying and convinced me that CM's are a MUST....
blufishin is offline   Reply With Quote
Old 07-02-2015, 09:51 AM   #56
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Not all workers at tire centers have been motivated to do the job properly the first time, not realizing they could put someone at risk down the road with their indifferent attitude.
