Old 01-25-2009, 08:53 AM   #1
1979 29' Ambassador
Chipley , Florida
Temperatures of wheels
When using the Cen tech to check drum temperature, what is the temperature range?
Chipleyboy is offline   Reply With Quote
Old 01-25-2009, 03:24 PM   #2
mbmbstreamer's Avatar
2006 25' Safari SS SE
1969 27' Overlander
Martinez , Georgia
When I check my hub and tires, I expect to find that the temperatures are similar between hubs and between tires. I also expect to find very little difference between hub and tire. For a reference, I check the Tow Vehicle wheels and tires.
A couple of things to think about:
- If you have a turbo, the wheel and tire on that side of your truck will be warmer than the others.
- If the sun is bright and predominantly hitting one side, you will see higher temps on that side.
- If the trailer is not level (more load on one axle than another) you will see a slight difference in temperature.
I have been using the IR therm. for several years. It provides interesting information.
Matt
mbmbstreamer is offline   Reply With Quote
How Far Apart Are The Wheels? joopkeizer Axles 1 11-04-2007 11:32 PM
New Wheels 64Overlander 1960 - 1964 Overlander 1 03-10-2007 01:05 PM
Operating Temperatures guy99 Mechanics Corner - Engines, Transmission & More... 34 09-04-2004 02:25 PM
Wheels poorboycjs Wheels, Hubs & Bearings 2 10-31-2003 11:13 AM
Refrigerator temperatures-time davidz71 Refrigerators 7 07-02-2002 01:56 PM
