Old 08-03-2011, 12:40 PM   #15
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
Or, you could drill them out to the proper size and drive,or press a set of splined studs in like the replacements (and most drums) have, no locktite needed, and easy replacement if needed, cost? a set of studs and a drill bit.
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Wheel Hub greatlakes Tires 5 08-15-2011 07:13 PM
Hub caps for standard 14.5" rim Jephellis Wheels, Hubs & Bearings 3 07-31-2011 05:16 PM
Need Hub & Drum for '98 Cutter Marlind Brakes & Brake Controllers 3 04-25-2011 09:10 AM
Hot Hub /Wheel - Help diagnose Please Sav'h Steve Brakes & Brake Controllers 27 04-21-2011 08:39 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 07:40 AM
