Old 12-05-2010, 06:13 PM   #1
Boerne , Texas
Stripped wheel stud
One of my wheel studs is partially removed, I can see some threads. It came off that far very slowly with the air gun then stopped, then the stud came loose/stipped in the hub and now the stud spins when force is applied to it. I see that I have two options.
1. Grind off the nut and stud enough to get off the wheel, then remove hub and replace stud with a new one.
2. Grind off end of stainless hub protector and remove hub from spindle. Then from inside of brake drum, drill out stud. Will this work? The steel is probably soft enough to drill isn't it?
I expect that there could be damage to the brake drum/hub if the stud has spun inside it's hole. I expect that the cast iron hub/drum is harder than the stud and it is probably the stud that is stripped and the hub/drum once cleaned will accept and hold a new stud.
Any opinions appreciated.
Thanks.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley.
Tow With: 2006 Dodge 2500 Quad Longbox 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr programmer, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 12-05-2010, 06:36 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I'd go for #1 provided there is enough rom to get a grinder in there without messing up the wheel.
Do the lug nuts have those decorative metal covers on them? If so, and if you could cut of the metal cover with a dremel or some such, would there be enough room to get a nut splitter onto the lug nut? might be another option?
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-05-2010, 07:16 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Grinding will work and be messy. Try controling the die grinder in that tight of space - very tough.
I would opt for a nut spliter. Typically used on regular open ended nuts, they will work on wheel nuts but may require two applications to get it to split all the way off. Seen it done, you can get one at Sears or good tool stores, not very expensive. You apply torque with a socket wrench or wrench. The stud should pound right out. If not apply light heat to the drum in a circular motion around the stud but not directly on the stud, give it a good smack.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-05-2010, 07:31 PM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Just make sure you tape you wheel off good,so those sparks don`t ruin the wheel.I think a few small drimmel cutting wheels should cut the stud.Then replacing should be fine,I doubt the spline in the hub are bad. Dave
easyride is offline   Reply With Quote
Old 12-05-2010, 09:44 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
I'd put wet towels on the tire and wheel and cut the lug nut and stud off with a torch. Much more predictable in tight quarters than a grinder.
Old 12-06-2010, 07:52 PM   #6
Boerne , Texas
Thanks ya'll. I hadn't thought of the nut splitter (not something you do off of the high diving board). I think I'll try that, plus I'll have an extra tool hangin' around after that. I have to find a new stud too, probably a local parts store will have one.
The wheel nuts are solid. Any sources for the exact ones?
James B.
Old 12-06-2010, 08:20 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Any good tire shop should have the correct lug nut.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-08-2010, 09:53 AM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The stud and nut should be harder metal that the drum.
If the stud has spun in the drum the metal in the drum can be built up and a new stud inserted. Only do that if the drum is in very good condition. If not in good condition replace the drum.
Then don't use the service that installed the wheel prior to this event.
>>>>>Action
Old 12-08-2010, 11:05 AM   #9
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I would also try to wedge something between the wheel and drum that will put pressure on the lug nut. Then try to turn the lug off.
If that didn't work then I would get a Dremel and several cut-off disks.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-08-2010, 12:01 PM   #10
1972 21' Globetrotter
nc , North Carolina
replaced many on autos,years past. get the lug nut off what ever way that you can. take drum to auto repair shop if you don't have a press and they will press the old one out and a new one in. auto parts store have most replacement studs. studs have groved oversize shoulders and are pressed back into the drum.
also you can cut them off with a tourch,done that.
rock60 is offline   Reply With Quote
Old 05-04-2011, 05:24 PM   #11
Boerne , Texas
wheel lug 1/2 20, 0.603 shoulder diameter needed.
I need a source for the wheel lug on my '91. I've looked at several parts stores and specialty bolt distributors but cannot find a close match. Does anyone have a source or an extra they'd part with?
Lug is 1/2 in thread pitch 20 , knurled shoulder diameter 0.603 +/-
several parts catalogs at O'Reilley auto parts and Napa autoparts were checked but they don't have the shoulder at 0.60 diameter??
Thanks in advance.
James B.
Old 05-04-2011, 07:14 PM   #12
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Thanks in advance.
Any Airstream dealer or trailer repair shop either has them, or can get them for you.
Old 05-04-2011, 07:15 PM   #13
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
I would look into a more trailer specific supply store - RV, work trailer, etc.... They may be more of a help here than a general auto supply store. Of course you could always go to an Airstream dealership but be prepared for price shock. The hubs are notAirstream specific and therfore should be available without that big a search - just the right source.
Old 05-04-2011, 07:58 PM   #14
1985 31' Excella
Fresno , Texas
I would use a wafer cutting disk and just cut a slot until you get close to the end of the nut and then use a chisel or screwdriver and spread the sides of the nut.
I just bought axles for a utility trailer on I-45 5-6 miles north of downtown. They have all kinds of axles hubs brake magnets They carry Dexter parts.
Trailer Wheel and Frame
8222 N. Freeway
Houston, Texas
281 931 7777
Wsmith is offline   Reply With Quote
Broken Wheel Stud gsmithii Wheels, Hubs & Bearings 12 10-11-2010 01:09 PM
Broken wheel stud 65 Caravel kevinkatz Wheels, Hubs & Bearings 7 07-07-2009 06:31 AM
Stud Welder The Flintstones Ribs, Skins & Rivets 11 04-24-2009 04:27 PM
Wheel stud removal? TomW Axles 13 07-28-2004 04:42 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
