Old 03-30-2008, 03:45 PM   #1
1967 24' Tradewind
gilbert , South Carolina
Stripped lug bolt holes
While trying to service the brakes on my 76 sovereign project, I stripped two lugs when removing the wheel. Evidently the previous owner had the tire changed and the changer overtorqued the bolts. I checked the lug bolts and there were pieces of hub lodged in the threads of the bolt. I checked the bolts and I thought the bolt size is 1/2 by 20 thread, I cleaned the threads with a set of 1/2 by 20 taps and the bolts still will not hold. I need to find a proper solution to my problem. Thanks in advance for any advice.
chris's 67 is offline   Reply With Quote
Old 03-30-2008, 04:17 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet HeliCoil Inserts
HeliCoil Heli-Coil ( HeliCoil Inserts ) Helicoils Screw Thread Inserts | Emhart.com inserts. My understanding is that they are stronger than the original threads. I have a Shimano 600 SIS shifters on an old road bike that came from the factory with them. Aluminum doesn’t make for strong threads, so the factory installed them. A Google shearch will show up many sources, this site has good information. You can probably get them at an auto parts supply.
Vaughan
Old 03-30-2008, 04:52 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I have used Heli-coil thread inserts many times to repair stripped threads, but I would not use them on something that is to be removed and replaced over and over such as repairing wheel lug holes. When you remove the lugs, sometimes the coils will be bonded to the lugs and come back out.
Old 03-30-2008, 05:27 PM   #4
Retired.
. , At Large
Plus the price of the HeliCoil kit would come close to the price of a new drum. If you wanted to, now would be a good excuse to retrofit your drums with studs and lug nuts.
lug nut/bolt question.... Kistler Wheels, Hubs & Bearings 13 01-25-2006 02:15 PM
no answer on the lug bolt question donhardman Wheels, Hubs & Bearings 3 05-04-2005 11:50 AM
lug bolt size airtim Axles 8 03-09-2005 09:55 PM
How to replace lug bolt? frozen chosen Axles 1 05-01-2004 05:23 PM
Lug Bolt Size for '78 Sovereign dinoburb Wheels, Hubs & Bearings 2 03-20-2004 03:34 PM
