Old 03-18-2010, 11:48 AM   #1
2005 28' International CCD
Diamond Bar , California
Steel wheels
I'm considering getting an extra set of wheels with tires to keep on my Airstream while sitting for a long time. Are there any inexspensive wheels that will fit? Like Chevy of Toyota etc? thanks
BCMC27 is offline   Reply With Quote
Old 03-18-2010, 12:00 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
What do you consider "inexpensive"? Etrailer has 6 on 5 1/2 white spoke wheels for $35 each.
Bill
Just my personal opinion
Old 03-18-2010, 12:22 PM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Try this?
Every Winter...cheaper that wheels and tires plus takes the load off the axles.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-18-2010, 12:33 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Also what do you consider "a long time"?
Tires have a shelf life of around 5 years, regardless of how they are stored. I wonder if the extra work of storing the tires separately is worth it.
Similarly I'm not sure that putting the trailer up on jacks to take the weight off the axles will accomplish anything. Maybe for storage of more than a couple of months. I dunno.
Old 03-18-2010, 12:44 PM   #5
Rubber, when stressed, will, in time, adapt to that stress.
Removing the weight off of a torsion axle, relieves the stresses on the rubber rods.
That helps the rubber rods, to have a much longer productive life.
Old 03-18-2010, 01:13 PM   #6
2010 27' FB Classic
N/A , Texas
Chevy S10 wheels will fit. I got a set from a local junk yard and painted them. Junk yards even sell old tires to fit. My junk yard set is still holding air for over 10 years. There all cracked up but good for when storing the trailer.
Andy has a point, if you are going to store it for a long time take some weight off the axles. But just for 2 months the extra wheels and tires work for me.
Old 03-18-2010, 01:39 PM   #7
Bluto.
Just because the wheel fits, means absolutely NOTHING.
You must use wheels rated at a minimum of 2600 pounds, each.
If the trailer will never be on the road, then and only then, you can use anything.
Old 03-18-2010, 02:14 PM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
My sword is sheathed
Originally Posted by ROBERT CROSS View Post
Bob,
I asking, not picking on you: What does wrapping the hubs up accomplish?
My first impression is the trapped moisture from condensation would cause problems.
Tom
Old 03-18-2010, 03:46 PM   #9
2010 27' FB Classic
N/A , Texas
Originally Posted by Inland RV Center, In View Post
Bluto.
I know that. The poster wanted a wheel just for storage purposes. An S 10 wheel does work for that purpose! I have used those wheels for years as I have stated. They do work for storage, not for the road.
Old 03-18-2010, 05:50 PM   #10
Originally Posted by TomW View Post
Bob,
Tom
Do'n it 7 years now...noth'n traped yet.
Your welcome to come on up and check it for condensation anytime.
PFC
RLC
Old 03-18-2010, 06:23 PM   #11
What has been accomplished in seven years by wrapping the hubs?
Tom
Seven years of nothing trapped, not even moisture....; Piece of mind.
Spring makeready made easy.
PFC
RLC
Old 03-18-2010, 07:21 PM   #12
2010 27' FB International
Birmingham , Michigan
Bob,
Tom
Where exactly do you place the jacks?
Aquabud is offline   Reply With Quote
Old 03-18-2010, 07:22 PM   #13
Where exactly do you place the jack stands?
Thanks.
Old 03-18-2010, 07:24 PM   #14
Does storing over the winter months require that other tires or jack stands be used? Does something happen to the tires/wheels on the AS? I'm just taking delivery of a new 27FB and would like to do what is best.
Original Steel Wheels? '63 GT cvkey Wheels, Hubs & Bearings 2 12-31-2009 08:15 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
Steel vs. Aluminum wheels HansenClan Wheels, Hubs & Bearings 5 09-15-2009 02:45 PM
Airstream steel wheels davidz71 Our Community 5 05-23-2002 07:50 AM
Airstream steel wheels davidz71 Wheels, Hubs & Bearings 0 05-21-2002 05:18 PM
