03-18-2010, 11:48 AM
2005 28' International CCD
Diamond Bar
Steel wheels
I'm considering getting an extra set of wheels with tires to keep on my Airstream while sitting for a long time. Are there any inexspensive wheels that will fit? Like Chevy of Toyota etc? thanks
03-18-2010, 12:00 PM
1979 23' Safari
1954 29' Liner
Orange
What do you consider "inexpensive"? Etrailer has 6 on 5 1/2 white spoke wheels for $35 each.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
03-18-2010, 12:22 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Try this?
Every Winter...cheaper that wheels and tires plus takes the load off the axles.
03-18-2010, 12:33 PM
1993 34' Excella
Estancia
, New Mexico
Also what do you consider "a long time"?
Tires have a shelf life of around 5 years, regardless of how they are stored. I wonder if the extra work of storing the tires separately is worth it.
Similarly I'm not sure that putting the trailer up on jacks to take the weight off the axles will accomplish anything. Maybe for storage of more than a couple of months. I dunno.
03-18-2010, 12:44 PM
Corona
Rubber, when stressed, will, in time, adapt to that stress.
Removing the weight off of a torsion axle, relieves the stresses on the rubber rods.
That helps the rubber rods, to have a much longer productive life.
03-18-2010, 01:13 PM
2010 27' FB Classic
N/A
Chevy S10 wheels will fit. I got a set from a local junk yard and painted them. Junk yards even sell old tires to fit. My junk yard set is still holding air for over 10 years. There all cracked up but good for when storing the trailer.
Andy has a point, if you are going to store it for a long time take some weight off the axles. But just for 2 months the extra wheels and tires work for me.
03-18-2010, 01:39 PM
Corona
Bluto.
Just because the wheel fits, means absolutely NOTHING.
You must use wheels rated at a minimum of 2600 pounds, each.
If the trailer will never be on the road, then and only then, you can use anything.
03-18-2010, 02:14 PM
1967 26' Overlander
Huntsville
, Alabama
My sword is sheathed
Originally Posted by ROBERT CROSS
Bob,
I asking, not picking on you: What does wrapping the hubs up accomplish?
My first impression is the trapped moisture from condensation would cause problems.
Tom
03-18-2010, 03:46 PM
2010 27' FB Classic
N/A
Bluto.
I know that. The poster wanted a wheel just for storage purposes. An S 10 wheel does work for that purpose! I have used those wheels for years as I have stated. They do work for storage, not for the road.
03-18-2010, 05:50 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by TomW
Bob,
Tom
Do'n it 7 years now...noth'n traped yet.
Your welcome to come on up and check it for condensation anytime.
03-18-2010, 06:23 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
What has been accomplished in seven years by wrapping the hubs?
Tom
Seven years of nothing trapped, not even moisture....; Piece of mind.
Spring makeready made easy.
03-18-2010, 07:21 PM
2010 27' FB International
Birmingham
, Michigan
Bob,
Tom
Where exactly do you place the jacks?
03-18-2010, 07:22 PM
Birmingham
, Michigan
Where exactly do you place the jack stands?
Thanks.
03-18-2010, 07:24 PM
Birmingham
, Michigan
Does storing over the winter months require that other tires or jack stands be used? Does something happen to the tires/wheels on the AS? I'm just taking delivery of a new 27FB and would like to do what is best.
03-18-2010, 07:30 PM
2010 27' FB Classic
N/A
Basically it's just a way of saving your good tires for traveling. They will last longer if they are not on the trailer all the time exposed to the elements. You really don't have to do anything and the trailer will be fine but the tires may not last as long.
The part about the axle is a debated subject and there are a lot of threads on that subject. Do a search to find them and decide for yourself, some people do the jack stands, some don't, some change out the rims and tires and some don't..
03-18-2010, 07:40 PM
1993 34' Excella
Estancia
, New Mexico
Not too many owners take the wheels off and jack up the trailer. I asked earlier what does jacking accomplish. The answer, extending the axle life makes sense. Is it required? No.
It looks like the jack stands are under the fishplate to which the axles are mounted. That's where I would put them. You don't necessarily have to take the wheels off to take the weight off the axle. Just jack it up a couple of inches. Personally, if I had the wheels off I would also put jackstands or blocks under the tongue and frame in the rear of the trailer, but put most of the weight on the axle jacks.. To me it sounds like balancing the trailer only on 4 jacks near the axles is inherently unstable and the whole kit and kaboodle could go over like dominoes.
03-19-2010, 04:35 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Axle ratings
POI...
If you check your spec. sheet you will probably find what I did.
GVWR of the trailer...7300lbs. GWR of the axles...7000lbs.
It's not easy when boondocking to stay under the axle rating,(full fresh,LPG, supplies etc.)
Basicaly it's on stands to help extend the life of under-rated axles...Thank You Airstream.
Tires, alloy wheels tend to deteriorate rather quickly in winter around here.
Sitting on 4 stands has kept it stable thru many winter storms/winds off Lake Erie with no dominoes.
Not recommending it for anyone, it's just what I do for Winter storage....has worked well for two AS over 23yrs.
Sweet Streams...
03-19-2010, 08:07 AM
Retired.
, At Large
The S 10 has five lug wheels, most Airstreams have six lug wheels. Count your lugs before purchasing.
The 6 lug, large hub Nissan wheels will also "fit", as will the 6 lug, old style Chevy truck wheels.
03-19-2010, 10:47 AM
2010 27' FB Classic
N/A
No matter what Chevy wheels you get they have to be 6 lug type to fit. Just Google Chevy s10 6 lug wheels and see that they made them since 1987.
