Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 01-26-2003, 05:45 AM   #1
art
Profile:
steel rims
Im traveling across the country this year ,and would like to have a spare wheel and tire just in case what type of rim can I use (chevy ford dodge etc) or are they special steel rims? this is for a 77 31ft soverign . If special where can I find one?
art is offline   Reply With Quote
Old 01-26-2003, 09:25 AM   #2
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
camping world has a rim . i bought a set for my 73. and painted the rims with aluminum paint they looked great. lol
al
wb13798 is offline   Reply With Quote
Old 01-27-2003, 08:54 AM   #3
Commercial Vendor
Profile:  Corona , California
A "rim" is the outside part of a wheel. The term came from the old "split rim" wheels.
A wheel is a disc, joined to a hub, and is designed to turn around an axle or shaft.
BUT!!!!!!!!
Just because a wheel may fit, there is a great difference between wheels. A proper steel wheel for an Airstream trailer, must have a rating of at least 2600 pounds. If less than that, they "WILL" fail.
To see the result of using a wheel with an unknown rating, or an inadequate rating, go to our web site and see the photos of a "junk yard" wheel, in the articles section. inlandrv.com
If that doesn't convince someone of the hazard of improper wheels, nothing will.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 01-27-2003, 10:26 AM   #4
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Wheels
Get an RV wheel. Acquire it new from a RV dealer, or used from a RV salvage yard. There is a salvage yard here in Phoenix and several across the country. I am just not familar with the Northeast. - Note the bolt pattern will likely match to an automotive axle, however an automotive wheel is too weak.
Match the spare tire with the rating* for the rest of your tires. Do not skimp on tire or wheel. (It messes up a good vacation.) Then have it all balanced.
* The rating on the tire side wall is for max inflation. If you add the rating for all of the tires on the ground, it should be greater than the total fully loaded weight of the trailer. If not than new tires are needed.
>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Pingbacks are On
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
Rims from Inland RV jlawrence Parts Archive 3 11-23-2003 07:09 PM
Keeping Tires & Rims? Tinsel Loaf Tires 4 11-08-2003 04:23 PM
Rims For a 1992 34' Excella NEW2AS Wheels 1 04-07-2003 03:53 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
SEO by vBSEO 3.1.0
