Old 05-20-2011, 02:51 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Steel / Aluminum wheel question
The other day I got a set of rough aluminum wheels for my trailer. They were in pretty rough condition so I promptly cleaned them up. Took the smoothe surfaces down to bare metal, primed and painted one using stuff I bought at the NAPA store. Came out nicely and now I have the other 3 primed and ready to paint. Now comes the big question. My trailer is an '85 Excella. I need to find a good source to buy new center caps and lug nuts. So that is question #1. Question #2 is, will I find the lug nut studs to be long enough for the thicker alminum wheels or will I have to replace the studs ???????
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-21-2011, 03:45 PM   #2
retired USA/USAF
2001 30' Excella
Otay. Today I answered my own question. I jacked up one side and removed the wheels to make the conversion. I tried one of the aluminum wheels just to make sure. The studs are plenty long enough so I'm all set and I found a source of center caps and lug nuts. I took one of the nuts with me so I can double check the thread and order the right ones.
Roger in NJ
TAC - NJ 18
Old 05-21-2011, 05:24 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Glad it is working out! Post some pics when you can.
Lance
Top is offline   Reply With Quote
Old 05-21-2011, 06:40 PM   #4
retired USA/USAF
2001 30' Excella
Yes I will try. I was wondering if there is a problem with the aluminum wheel oxidizing and bonding itself to the drum casting. I've had problems with alum wheels on other cars. They stick and have to be pounded off. I was thinking if it would be wise to try and make a gasket to sandwich between the wheel and the drum. Just a thought. I'll ask when I order the caps and lugnuts on monday.
Roger in NJ
TAC - NJ 18
Old 05-23-2011, 12:31 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If you are concerned with this you could use just paper and make a gasket or use a liquid gasket maker. Permatex comes to mind as far as a brand.
In AZ we don't have that issue. And with annual inspections you may not either. Leave the wheels on there for several years and slosh around in snow and ice mixed with salt that may be the solution for a bond that needs a pounding to break.
>>>>>>>>>>>>>>>Action
Old 05-23-2011, 12:54 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I use Permatex® Anti-Seize Lubricant and it works great. Just a little to cover the mating surface on the drum and the wheels won't stick. Also works great on lug threads and even lubing brake parts. A little of this stuff goes a long way. Keep it a thin coating.
It's also what you use any time you put steel threads into aluminum, including spark plugs into aluminum heads. Also, for diesel injectors.
Vaughan
Old 05-23-2011, 03:06 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
This is what I was thinking. Thanks for the name and the link!
>>>>>Action
Old 05-23-2011, 03:28 PM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
>>>>>Action
I appreciate the thanks, too.
It's great stuff. I also use it on battery posts and clamp bolts. Again, use it sparingly and wipe off any access.
Also, once you get it on your hands it seems got get everywhere. At least it is easy to get off, unlike some things.
Vaughan
Old 05-23-2011, 05:02 PM   #9
retired USA/USAF
2001 30' Excella
Thanks all. And I just happen to have a can of anti-sieze. The good stuff that's older than I am. Left over from my fathers garage. I use it all the time.
Got my wheels all done today. I have 2 wheels off my trailer to have mounted tomorrow. Will get the other two after I put these first 2 back on.
Roger in NJ
TAC - NJ 18
Old 05-29-2011, 07:06 PM   #10
retired USA/USAF
2001 30' Excella
OK Top, here are the photo's you requested. Job is done and installed and not so bad a job. If I do say so myself. A few bucks and some elbowgrease and the wheels came out pretty darn nice. It helps to have friends in low places to get jobs like this done quickly and efficiently.
Bye the way. Is that TOP vs. bottom ??????
Happy Memorial Day to all
Roger in NJ
TAC - NJ 18
Old 05-29-2011, 07:09 PM   #11
retired USA/USAF
2001 30' Excella
DUH. I guess it would be appropriate to include the pix.
ID:	131032   Click image for larger version
Roger in NJ
TAC - NJ 18
Old 05-29-2011, 07:27 PM   #12
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Nice work! They look like new.
Lol! Yes like "At the top of the food chain".
Lance
Old 05-29-2011, 07:49 PM   #13
retired USA/USAF
2001 30' Excella
Thanks for the compliment. Not a difficult job. I purchased them from a forum member and they had a lot of, I guess some type of corrosion. It spreads just under the clearcoat and looks pretty bad. She upgraded to 16" wheels and I bought the 15s. Can't wait to get out on the road with my "NEW" wheels. Looks pretty classy. Have one front panel to replace one of these days to make things shipshape. But that's another story and another time.
Stay well. See ya on the road sometime.
Roger in NJ
TAC - NJ 18
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Replacing Steel Wheels with Aluminum crookedroad Wheels, Hubs & Bearings 8 02-03-2011 11:27 AM
aluminum or steel rayandre LP Gas, Piping, Tanks & Regulators 3 01-01-2011 11:55 AM
