Old 04-08-2015, 08:03 PM   #1
North Central , USA
Stainless Steel Lug Nuts?
Has anyone found a source for replacement stainless steel lug nuts? I've gone through 2 sets (in about 6 years) of 'lifetime' chrome plated sets that keep rusting, & I live in Central Texas.
I cannot seem to locate any that have the 'bulge' before the taper. There are plenty with the taper but no bulge, if that is important. ??
After a bad experience with the A/S OEM 2 piece lug nuts, I'm not going there again.
RivetED is offline   Reply With Quote
Old 04-08-2015, 08:13 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Thanks for asking this question. I have the same issue with the lug nuts on the replacement wheels we bought a few years back. Wheels look great, lug nuts bad.
www.nesa.org
Air No. 6427
Old 04-08-2015, 09:25 PM   #3
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
There is a post or two on the Forums about McGuard lug nuts. I have purchased a set, but have just not gotten around to putting them on. Appear to be very high quality. They have a website, or are on Amazon.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 04-08-2015, 09:26 PM   #4
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
That might be spelled "McGard". Not sure.
Old 04-08-2015, 09:27 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
They probably cant be found because they are likely not made.
Stainless threads have a way of galling and seizing up. They would be bad news as lug nuts.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-08-2015, 09:50 PM   #6
firstwave's Avatar
2006 30' Classic
Santa Fe , New Mexico
I used McGard #64010 found on Amazon when I switched to 16" wheels.
firstwave is offline   Reply With Quote
Old 04-08-2015, 10:19 PM   #7
Southwestern , Ohio
Interestingly, the McGard lug nuts referenced above are not stainless steel. Their claim to fame, among other things, is their triple nickel/chrome plate. Lug Nuts/Lug Bolts
I can readily believe this; there's chrome plate and then there's chrome plate. If you've ever looked at an OEM chrome bumper next to one replated by a real chrome plating shop you know what I mean.
Nuvite-F is offline   Reply With Quote
Old 04-08-2015, 11:08 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
For sure.. All chrome is not created equal,,,, not even close to equal.
Old 04-09-2015, 05:04 AM   #9
2000 30' Excella
Toledo , Ohio
I got mine from Discount Tire in 2013 they have held very well they said they were SS .
woodfox45 is offline   Reply With Quote
Old 04-09-2015, 06:12 AM   #10
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Easy enough to test for stainless. Put a magnet to them. Also remember that stainless does rust, it just takes it longer.
MICHAEL
Old 04-09-2015, 06:21 AM   #11
1981 31' Excella II
New Market , Alabama
A little steel wool brillow pad scrubbing and then a coat of wax will fix most rust problems. Unless something is Chrome plated really well it will chip and come off and as soon as there is a pinhole, it will rust. Impact drivers used to remove lug nuts will chip chrome because it is brittle.
Perry
Old 04-09-2015, 06:31 AM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Deforming the metal on top or beneath the surface will increase "rust" and peeling. I saw this a lot on "bad chrome" on motorcycles. It is really difficult to build things which cannot be "over tightened". A stainless "cover" crimped over the lug will be the closest compromise IMHO.
To me, I would like to see a removable cover like on my truck wheel lug nuts. That should be "doable..."
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-09-2015, 06:57 AM   #13
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
I put these on my boat trailer than gets dunked in salt water:
http://www.amazon.com/10-pack-SOLID-...steel+lug+nuts
No rust yet.
BambiTex is offline   Reply With Quote
Old 04-09-2015, 07:12 AM   #14
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Stainless is a "softer" metal, and is not designed to withstand the loads encountered as a wheel fastener. I have stainless roller rockers in one of my engines, but the loading is less and different than a wheel.
You WANT hardened steel. There is a reason you don't see stainless or aluminum lug nuts.
NavyCorpsman is offline   Reply With Quote
Converting from lug bolts to studs and lug nuts tim781996 Wheels, Hubs & Bearings 7 11-22-2014 09:23 AM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
lug nuts bambi david h Axles 2 02-10-2003 08:59 AM
