Old 03-01-2009, 07:45 AM   #1
coffeydelsol's Avatar
1986 25' Sovereign
Ocala , Florida
Squeeky Hubcabs?!?
I know that sounds weird, but our hubcabs squeek horribly while moving. When we first bought it we thought is was something in the wheel itself or the brakes. We have since replaces the brakes & hubs etc.
While test driving after the replacement, darn if it still was squeeking. We removed all the hub caps and it stopped. (Thank goodness - you should have seen the looks we were getting). Any suggestions? It looks tacky without the caps!
coffeydelsol is offline   Reply With Quote
Old 03-01-2009, 07:58 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
How about putting them back on one at a time to see which one or if all of them are the culprits. Possibly replacing the clips on them might solve your problem. Or try other hub caps to see if they do the same thing.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-01-2009, 08:29 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Redneck engineering at its finest...
I had some metal hubcaps that would squeak whenever the vehicle was moving. My redneck solution was to run two turns of duct tape around the circumference of the clips, then reinstall the hubcaps. The duct tape helped keep the clips from shifting as the wheels turned, and dampened whatever of the squeak was left.
It was cheaper than new hubcaps...
Old 03-01-2009, 07:47 PM   #4
1986 25' Sovereign
Ocala , Florida
We thought about something along that line. We were thinking about weatherstripping that was sticky on one side, hoping the cushion would stop the noise.
Old 03-01-2009, 09:35 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Squeaky hub caps.
Hi, after working at new car dealers since....................any way the first thing you need to do is make sure everything is clean especially where the hub caps or wheel covers make contact with your wheels. Next make sure the clips that hold them on are tight. We used to bend the clips to make a tighter fit. Two other things that work, but could cause other problems is lubrication [grease, WD 40, Etc.] and electrical tape. The problems are: Lubricants attract dirt. And tape may cause your hub caps / wheel covers to fall off. But not always.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-01-2009, 10:36 PM   #6
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Bob has the base's covered.
When I put these on our old 63 Safari the squeeks went away for good.
https://www.kmjent.com/cart/product....uctid=948&js=n
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-02-2009, 07:00 AM   #7
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
It can happen. I had it happen on my first car. The rims flex and the covers were rubbing against them. I removed the caps and the sound went away.
Try some light lube on them.
Michelle TAC MT-0
Sarah, Snowball
Old 03-02-2009, 08:41 AM   #8
Twotone's Avatar
Minooka , Illinois
I had the same problem on a car. I bent the clips to make them fit tighter and the noise stopped.
Tom
Twotone is offline   Reply With Quote
Squeeky Wheel Gets the Oil! Dureedesign On The Road... 3 05-06-2008 08:05 PM
