Old 05-27-2008, 02:20 PM   #1
HansenClan's Avatar
1965 26' Overlander
Encinitas , California
Images: 22
Question Split Rims- Friend or Foe?
I recently purchased a partially restored 1965 Overlander 26", and, it has split rims! They appear to be in good condition with good tread and sidewalls on the tires. We are planning a trip this summer of about 3000 miles (round-trip), and I have heard quite an array of opinions on the split rims. So, I am here, requesting help from the Forum Gods... "Speak to me all knowing ones"
Thanks ahead of time...
HansenClan is offline   Reply With Quote
Old 05-27-2008, 02:43 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Welcome to the forums.
I would get rid of the split rims. They can be very dangerous and most tire shops will not work on them.
As far as the tires go, check the date code on the tires and if they are more then 3 years old, I would replace them as well.
Richard
Old 05-27-2008, 04:16 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Exclamation
Split rim wheels are usefull if you intend to repair the tires on the road yourself. They require tube tires . They require proper handling to be serviced with any degree of safety. If you do not intend to repair tires on the road yourself, then ditch the spilit rims because many tire shops will not or cannot work with them through lack of trained personnel and equipment. They were the standard once, but vanished with the advent of tubless tires. I use them on my International because I do offroad/backkroad work and find it convenient to repair the tube rather than trying to carry a couple of tires on the rim as spares. The main objection to split rims is that, if the rim is not seated correctly it can get loose during inflation and cause mayhem. They are not the rim for the inattentive!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-27-2008, 05:22 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you do decide to keep the split rims so you can repair your tires yourself, get at least two heavy chains with screw-together links to join the chain together around the tire/rim assembly. When you inflate the tire, make sure the chains are around them. If the rim comes apart, at least the chains will keep it (hopefully) from tearing someone's head off.
Old 05-27-2008, 06:35 PM   #5
HansenClan's Avatar
1965 26' Overlander
Images: 22
Thanks for the input!
Are they dangerous to drive on, or just to change?
Old 05-27-2008, 06:46 PM   #6
Well Preserved
1993 21' Sovereign
They are only specifically dangerous when inflating a completely deflated tire.
Old 05-27-2008, 07:02 PM   #7
HansenClan's Avatar
1965 26' Overlander
Images: 22
My plan has been to carry one "new" spare, with crossed fingers and a bit of luck. If we need to use the spare, then off come the split rims and on go all new wheels and tires at the nearest tire shop. I am not going to attempt/learn about (even being very mechanically inclined) split rims the hard way... Any thoughts on this plan?
It is awesome to have these forums available!
Old 05-27-2008, 07:05 PM   #8
Well Preserved
1993 21' Sovereign
Your trailer will take 15"x6" (or 7") 6 lug, 5 1/2" bolt pattern, zero offset, 2600 pound wheels.
Old 05-27-2008, 07:19 PM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Check the age of the tires you have mounted now. If the tires are old, you may want to accelerate your plan.
Richard
Old 05-27-2008, 07:21 PM   #10
HansenClan's Avatar
1965 26' Overlander
Images: 22
Thumbs up Thanks!
That was my next question...
Old 05-27-2008, 07:28 PM   #11
Well Preserved
1993 21' Sovereign
We have ESPN...
Old 05-27-2008, 07:46 PM   #12
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
This is NOT a joke. I've seen MANY serious injuries from split rims demounting upon pressurization, sometimes literally tearing arms off people, sometimes causing fatalities from rim / cranial impacts. Almost any place I know that will work on them is required (OSHA, I suppose) to inflate them inside a retaining cage intended to keep the rim from going interplanetary if it disengages. Rid yourself of them just as soon as you can if you are not very experienced with them and/or unless you do want to do backcountry work and you want to become very experienced with them. But you only will get one mistake.
AirsDream is offline   Reply With Quote
Old 10-17-2008, 07:24 PM   #13
1972 Travelux Princess 25
Cobourg , Ontario
Split rims were only used on very stiff, truck tires. So stiff it was next to impossible to force them over the rim.
Today's radial tires are no where near this stiff. You do not need split rims, get new rims. You might keep the split rims for a museum piece but not for regular use.
Besides split rims cannot be used without tubes, and tubes are something you don't want at today's hiway speeds. They retain too much heat making the tire more likely to blow.
Ganaraska is offline   Reply With Quote
Old 10-17-2008, 11:20 PM   #14
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I would not wait until there is trouble on the road. At that point, you may not be able to easily buy the proper wheels. Change them before you hit the road.
Go to good new wheels with tubeless tires. That will avoid tube/heat problems as well as split rim problems. You really don't need any of that on the road.
61 globetrotter 6 lug split rims greenrig Wheels, Hubs & Bearings 15 03-28-2008 08:56 PM
Split Rims Julison Wheels, Hubs & Bearings 5 10-12-2005 08:49 PM
Free Split-Rims Jabba Tires 3 07-17-2005 07:39 PM
Original Split rims vs. something new saahieb Wheels, Hubs & Bearings 7 10-27-2004 02:19 PM
Source for Heating Element foe Norcold 624 srgntpepper Refrigerators 2 05-11-2004 05:02 PM
