Old 08-15-2014, 07:14 PM   #1
ljaecks's Avatar
1962 22' Safari
1964 26' Overlander
1965 26' Overlander
Wenatchee , Washington
Split Rims 1964 Overlander
We just replaced the tires & rims on our most recently acquires AS. Is there any reason the rims shouldn't go to the scrapyard?
I was told that not many people have the equipment to change tires on these rims so we switched to older Chevy rims. I'm not well informed about tires and wheels. So I don't know if everyone is steering clear of split rims or not. The tires are toast.
ljaecks is offline   Reply With Quote
Old 08-15-2014, 07:23 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Split rims on trailer wheels went by the wayside by 1970 or earlier. I recommend you scrap them. I just scrapped one split rim wheel we found in my sons 69 Globetrotter in the spare tire tray underneath. Mounting tires on split rim wheels can be dangerous.
David
Old 08-15-2014, 07:36 PM   #3
Kevin245's Avatar
Split rims are old school which is cool; however they are inherently dangerous and should be rendered nonfunctional IMO. I'd then dispose of them in the nearest steel recycle bin.
William C. Swinney
Old 08-15-2014, 07:43 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Junkyard rims are no less dangerous on the3 Airstream. Be careful. A new rim, a correct rim, is less that 45 dollars.
Old 08-15-2014, 07:45 PM   #5
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
I have had Split Rims on numerous vehicles. Not many can or will work with them!! If done properly no issues, if not done properly ...................... DAMN!
I just chose 7-14.5 Tires for my wheels, why not stay as close as you can to original but maybe consider ditching the "split rims"!
Steve
1958 California Built 18' #18-4092
https://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 08-15-2014, 07:48 PM   #6
Each wheel should have a rating of at least 2600 pounds each.
Auto wheels, never reach that rating, and should not be used.
Andy Rogozinski
Inland RV Center
Corona, CA
1964, 1964 overlander
Split Rims- Friend or Foe? HansenClan Wheels, Hubs & Bearings 15 10-18-2008 08:42 AM
61 globetrotter 6 lug split rims greenrig Wheels, Hubs & Bearings 15 03-28-2008 08:56 PM
Split Rims Julison Wheels, Hubs & Bearings 5 10-12-2005 08:49 PM
Free Split-Rims Jabba Tires 3 07-17-2005 07:39 PM
Original Split rims vs. something new saahieb Wheels, Hubs & Bearings 7 10-27-2004 02:19 PM
