Old 11-21-2008, 02:40 PM   #1
Riveting Experience
1977 27' Overlander
Raleigh , North Carolina
Send a message via Skype™ to iverson
Spare wheel
Does anyone know what the factory wheel size is for a '77 Overlander. I would like to pick up a steel wheel for a spare. There must be a cross reference wheel available.
iverson is offline   Reply With Quote
Old 11-21-2008, 04:54 PM   #2
The drums on your Airstream are for 12 inch brakes.
The drums have 6 lugs.
The correct steel wheel size is 15 inch, with 6 holes on a 5 1/2 bolt circle, zero offset.
The wheel must be rated at 2600 pounds or more, to be compatible with the originals.
The above specs are assuming someone did not change the axles out to something different than original production.
Junk yard wheels do not fit the bill, since it's near impossible to determine the weight rating, or it's past history.
Correct spare wheel? Mike S Wheels, Hubs & Bearings 1 08-30-2008 02:12 PM
Wheel for Spare Tire azflycaster Wheels, Hubs & Bearings 2 11-05-2006 10:22 AM
Need spare tire and wheel Dan33764 Tires 17 06-19-2006 10:41 PM
Need spare wheel! AJr. Wheels, Hubs & Bearings 15 03-11-2006 07:59 PM
Need a new tire/wheel for spare. tenrsingr Wheels, Hubs & Bearings 10 02-06-2005 08:58 AM
