Old 09-08-2011, 09:25 AM   #1
Ag'71's Avatar
1971 27' Overlander
Springfield , Missouri
Should I replace the wheels?
Hi everyone, I've got a 1971 Overlander, and while my wheels look a lot better than Tabasco's, I was wondering, How do you know if you need new wheels? We've only made a few 100 mile round trip outings, close to home. I don't want a major issue if we decide to make a 1000 mile round trip outing. Thanks.
Ag'71 is offline   Reply With Quote
Old 09-08-2011, 09:28 AM   #2
Visual inspection, usually tells the story.
But, the inside of the wheel, is typically rusted, which depending on how much, dictates the replacement.
Old 12-02-2011, 05:39 PM   #3
Joebanjo's Avatar
1976 29' Ambassador
Wichita , Kansas
Had my first flat on my 1976 Ambassador 29'. Discovered the tire was fine, but the steel wheel had produced a pencil lead sized hole in the rim. Upon inspection, I found no rust and it seemed to be a perfect wheel. Now, after 35 years of service, I learned from some local trailer people, that tandem axle trailers, when turning, exert many times more lateral tension on the wheels than do say...an automobile. I figure that the factory wheels finally suffered from enough fatigue to produce a small rupture. Chatted with Andy and decided to purchase new wheels before taking off on another trip. The peace of mind is worth it!! Mike
Joebanjo is offline   Reply With Quote
Old 12-02-2011, 05:55 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Steel wheels sometimes develop fatigue cracks at the bottom of the curve where the tire is seated. I had two of them fail on my Lincoln Town Car. Under inflation can be a factor as well as alignment, design, load rating, miles of use, and conditions of use. Your trailer is 40 years old with an unknown history, so I would not be surprised by rim failing from fatigue. Like you say, if one fails can the others be far behind, so buy a new set.
Old 12-02-2011, 06:41 PM   #5
1981 31' Excella II
New Market , Alabama
Wheel Only 15 Inch 6 on 5-1/2 Inch Tires and Wheels | etrailer.com
About $50 each for steel about twice that for Aluminum.
Perry
Old 12-02-2011, 06:57 PM   #6
Always keep in mind that replacement wheels must have a rating of at least 2600 pounds, each.
Old 12-03-2011, 09:47 AM   #7
Joebanjo's Avatar
1976 29' Ambassador
Wichita , Kansas
Wheel replacement
Thanks Andy, I ordered those 2600 lb. wheels from you and they arrived yesterday..;-)
Old 12-03-2011, 09:59 AM   #8
1963 19' Globetrotter
Moline , Illinois
If they are steel wheels they can always be magnaflux tested as well as visually inspected. I'd rather have old US steel than new China steel.
63air is offline   Reply With Quote
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Looking for two newer 15" aluminum wheels Tallytown Wheels, Hubs & Bearings 0 04-29-2011 12:21 PM
Replacing Steel Wheels with Aluminum crookedroad Wheels, Hubs & Bearings 8 02-03-2011 11:27 AM
Putting modern wheels on a '79 blickcd Wheels, Hubs & Bearings 1 01-21-2011 10:16 AM
