Old 03-19-2011, 07:26 PM   #1
Ariz-Pacer's Avatar
1958 17' Pacer
Phoenix , Arizona
Exclamation Seals For Wheel Bearings ~ 1958 Pacer
I did an extensive search and found everything but what i needed.
I took my 58 Pacer in to a reputable RV dealer to get the bearings repacked before a trip next week. After disassembling the hubs they found that the bearings and seals needed replacement. So far so good. Apparently they found the outer bearings and seals. The inner bearings were another matter.
Apparently the last maker of the inner bearing seals went out of business 12 years ago. They put in a call to Airstream and had not heard back from them before closing Friday.
My question is; Does anyone have a line on these seals. Apparently they are or were leather/fiber? (?)
They also informed me that both sides of the trailer had broken leaf springs. So there is some work to be done there.
To answer your question, yes this is the original axle.
Any help or suggestions would be gratefully appreciated.
AZP
Ariz-Pacer is offline   Reply With Quote
Old 03-19-2011, 08:08 PM   #2
AZP
What's the number on the old seals?
Old 03-20-2011, 09:20 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
AZP,
Where in Phoenix are you? I might be able to lend you a hand.
>>>Action
Old 03-20-2011, 01:25 PM   #4
Ariz-Pacer's Avatar
1958 17' Pacer
Phoenix , Arizona
Originally Posted by Action View Post
AZP,
>>>Action
I am in Northeast Phoenix, 40th & Shea. The Pacer is at Bell Road RV.
Andy......."What's the number on the old seals?"
The seals are at the RV place and I can't find out until tomorrow morning.
I will get the number and let you know.
Thank you both for your replies.
AZP
Old 03-20-2011, 01:39 PM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Most members in the past that have had seal-bearing replacement questions have found that the parts are available at good auto parts stores like NAPA. The key is finding the number stamped on the seal. Parts like this are not Airstream specific.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-20-2011, 02:59 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Nice talking to you AZP! My trailer is at 40th and Thomas Road.
As Lee states above, a replacement can be had by dimensions versus application. Having the part # on the part works very well. The original leather seals may not have a # and you may not want to get a leather seal as more modern material has a far better service life.
>>>>>Action
Old 03-21-2011, 02:01 PM   #7
Ariz-Pacer's Avatar
1958 17' Pacer
Phoenix , Arizona
I just got a call they are still looking and the old seal is a Trostel 300-156-6.
Any information on a substitute is greatly appreciated.
John
Old 03-21-2011, 02:31 PM   #8
John
John.
Unfortunately, Airstreanm no longer stocks that grease seal.
The Trostel # is 30-156-6
The National # is 290944
The Chicago Rawhide # is 18808
The dimensions are ID. 1.875
OD. 3.002
thickness .375 inches.
Hope this helps you.
Old 03-21-2011, 04:56 PM   #9
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The #5 Napa store on this list has 2 in stock
Store Locator Search Results | NAPA Online
I called there and they used the National # listed above to look the part up.
>>>>>>>>>>>>>>>>>>>>>>Action
Old 03-22-2011, 10:50 PM   #10
Ariz-Pacer's Avatar
1958 17' Pacer
Phoenix , Arizona
John.
OD. 3.002
Andy and Action .......
Thank you both for your help in locating the grease seals. They actually found them at the NAPA store in Scottsdale as you suggested. The cross-reference part numbers were really a big help in finding them.
They had already taken the hub to the NAPA store previously and they told them that they didn't have anything like that. Once I got the numbers from Andy specifically the National number 290944 they were able to find the seal. Also the correct dimensions were a big help.
You guys are the greatest and thank you very much. As an aside note, I was so happy to get my Airstream back that I took the mechanics a case of beer as a thank you. I am virtually sending one to you guys too by email
John AZP
1958, 1958 pacer
Window seals and clips for '66-'67 globetrotters Alderman 1965 - 1969 Globetrotter 10 10-16-2014 07:16 PM
1960 Pacer lucymcdog Title, VIN & Registration 20 06-05-2011 02:11 PM
Monogram plaque on 1958 flying cloud mamateach Airstream History 21 03-18-2011 09:48 PM
