Old 12-31-2011, 08:40 PM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Scrub Factor
I've read many of the tire/ wheel posts but have not come across the info I'm looking for. If I change my 15" ST tires to 15" LT tires will I run a risk of damaging the rim, bearings, tires due to the scrub on a triple axle in a sharp turn? Evidently the ST tire is designed for the scrub factor trailers experience that the TV tires do not.
Same question regarding scrub with a switch from 15" ST to 16"LT.
BTW - would I have a clearance issue with 3-16" tires in a wheel well designed for 3-15" tires? Going to 16" will take out ~ 3" of the wheel well clearance if I understand the posts on this subject correctly.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Furnace Surface Area - Scrub Buds texascanuk Furnaces, Heaters, Fireplaces & Air Conditioning 1 12-10-2011 03:44 PM
Towing fudge factor hitman007 Sprinter and B-van Forum 4 09-29-2011 04:50 PM
