Old 10-09-2016, 10:35 AM   #1
F150 4X4 ProPride
mycloud9's Avatar
2015 30' Flying Cloud
Kingwood , Texas
Run without a single Wheel/Tire
I have heard a lot comments / questions about flat tires / no spare or no jack. Airstream says (in an emergency) you may run up to 100 miles at 30 mph with one Wheel/Tire removed. Without jack use leveling blocks or ramp under good axle to remove.
Personally? I call Good Sam!
Regards,
Dave
mycloud9 is offline   Reply With Quote
Old 10-09-2016, 12:26 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
When we were in Alaska on a caravan one trailer lost a wheel bearing that ripped out the side of the brake drum. We had extra bearings along, but not a drum. He pulled it 450 miles to White Horse at a low speed for almost 2 weeks on one wheel on that side. He left the trailer parked at the junction and went to Haines for the 3 days without the trailer. At Whitehorse he got the axle stub turned and got a new drum. So yes, you can limp in on one wheel on a side if you need to. Should replace both tires if you do so.
Bill M. is online now   Reply With Quote
Can I run a frig without its fan? mutcth Refrigerators 5 05-13-2012 11:08 AM
Can I run without the belly pans? DougZ Belly Pans & Banana Wraps 5 04-16-2011 12:23 PM
wheel/tire recommend for single ax. overlander (1957) p.dow Tires 23 10-01-2008 01:59 PM
Will fridge run without battery power? crazylev Refrigerators 9 09-01-2006 01:37 PM
1972 Shroud gone, can I run A/C without it? gypsymoth Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-15-2006 04:08 PM
