Old 07-26-2012, 06:51 PM   #1
1966 26' Overlander
Conover , Ohio
riveted wheel safe?
My 66 Overlander is getting new tires and I noticed that the wheel center is riveted in placed instead of being welded. None of the rivets seem loose but they do leak air which means I will need tubes. I know this is not the dangerous split rim we always hear about, but is this a wheel I can safely use? Thanks, TomE
project66 is offline   Reply With Quote
Old 07-26-2012, 07:29 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I'd say as long as it passes all other visual inspections for serviceability, yes it is safe to use. I don't like the idea of a tube in a tubeless tire. New powder coated rims are not that expensive if you have doubts. $50 each at etrailer.com
Lance
Top is offline   Reply With Quote
Old 08-01-2012, 10:21 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Rivited wheels (outside rim to center) were very common at one time. They are very safe and present no issues in that arena.
A tube is one way to make that repair or an adhesive would be another as liong as the adhesive is not applied any where near the flange of the rin where the tubeless tire seats and the adhesive is up for the extereme heat and pressure of teh job.
On a different wheel for a Toyota I made this type of repair for a pin hole leak in a cast metal wheel. The amount of adhesive used was very small and I had to do the repair twice because I did not let the adhesive cure. The tire was balanced after the repair and no one can see the repair since it is on the inside of the rim.
>>>>>>>>>>>>>>>>>Action
