Hi I have a 1978 31 ft Sovereign and I need to replace the wheels (two are bent) Does anyone know what size they are? Using a tape measure I'm guessing
15X6 with a 5 1/2 bolt pattern is this correct? Any help would be appreciated.
David,
generally, you should be in the ball park. ( 15x6, 6-hole pattern, 5 1/2 bolt spacing) For more information, I suggest you do a search with the term wheel size or wheel etc, and you will not only find much sizing information, but also good purchasing sources.
Good Luck, and a warm welcome to the forum!!
