Old 08-31-2010, 03:33 AM   #1
lpatkins's Avatar
1976 23' Safari
Chauvin , Alberta
Rim specs
I have a 76 safri with 15" 6 bolt pattern rims. I am need of a spare tire, can anyone tell me the specs on these rims so I can start searching the wreckers for one. Thanks all.
lpatkins is offline   Reply With Quote
Old 08-31-2010, 05:20 AM   #2
The correct wheel is 15" 6 lug on a 5 1/2" bolt circle, with a zero offset AND a 2600 pound rating.
Junk yard wheels are an absolute NO NO.
You do not know the history of those wheels, let alone the weight rating.
Old 09-28-2010, 11:22 AM   #3
Jackson , Wisconsin
I agree that junk yard wheels shouldn't be used. If you are looking at steel wheels, they specs should be stamped right into the wheel. It should give you size offset and weight rating right in the stamp. It can often be hard to see, but it should be there.
Good Luck!
streamair is offline   Reply With Quote
Old 09-28-2010, 01:09 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Buy a new wheel, only $43 on etrailer.com.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 11-04-2010, 10:28 AM   #5
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
Andy,
Will a 1978 TradeWind have the same rim specs?
John Hejmanowski
johnhh is offline   Reply With Quote
Old 11-04-2010, 12:59 PM   #6
Originally Posted by johnhh View Post
Andy,
John Hejmanowski
John.
Airstream has used that steel wheel with those specs for about 40 years or so.
So, yes, that's the correct one for your coach.
Old 11-08-2010, 07:17 AM   #7
1967 22' Safari
1978 25' Tradewind
Thanks everyone.
I was able to re-use the existing steel rims. Put new tires on the 78 Trade Wind and drove it from New Jersey to it's new home it New Lenox (Illinois).
Old 11-08-2010, 09:29 AM   #8
Jackson , Wisconsin
Thanks everyone.
Great to hear you got the information you were looking for!
Old 12-14-2010, 01:12 PM   #9
surrey , British Columbia
I'm looking for new wheels for my '72 Landyacht, it is stored about 300 miles away so I can't do my own measuring. can someone measure the width and depth of the axle. I need to know the cleance for baby moons or the caps, and some rims don't have the required size for the axle, some to big and some are to small.
thanks in advance,
Al.
IAFF2407 is offline   Reply With Quote
Old 12-14-2010, 01:36 PM   #10
thanks in advance,
Al.
Typically, the wheels should be ordered from the same place that has the hub caps, so that you don't have to worry about the hub cap fit.
Just make sure that the company that you chose, also knows the proper wheel for your coach.
Old 12-16-2010, 11:12 AM   #11
1971 27' Overlander
Phoenix , Arizona
So Andy would that be the same wheel spec for a 1971 27 foot Overlander as well?
rsqvet is offline   Reply With Quote
Old 12-16-2010, 11:17 AM   #12
15 X 6 6 lug on a 5 1/2 inch bolt circle, 2600 pounds minimum.
split rim or not??? G1obetrotter Wheels, Hubs & Bearings 11 05-09-2010 12:06 PM
North Rim dscluchfc On The Road... 18 07-12-2009 09:32 PM
Is this a split rim???? Benjo Wheels, Hubs & Bearings 21 04-18-2009 04:56 AM
Rim Size Tarheel Tires 4 03-22-2009 08:11 PM
Split Rim Or Not? Jabba Wheels, Hubs & Bearings 3 11-11-2002 07:43 AM
