Old 10-04-2016, 07:36 AM   #1
captainjohn's Avatar
St. Michaels , Maryland
Replacing tires, edge of rim rusty, problem?
Hi all,
Just bought some new Michelin Defenders for my 1974 31' sovereign. Had the Goodyear marathons in the cart until I checked on my most valuable resource (here), crisis averted.
As I began to refinish the rims I notice some rust (flaking away quickly) at the edge of my rim.
Wanted to stick with the 15s due to the budget, is this a big issue?
Name:	ImageUploadedByAirstream Forums1475588096.728906.jpg
Name:	ImageUploadedByAirstream Forums1475588134.829612.jpg
Thank you kindly,
John
captainjohn is offline   Reply With Quote
Old 10-04-2016, 07:44 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Not a big issue. Steel rust. Hit with a wire brush and repaint.
MICHAEL
Old 10-04-2016, 08:06 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Rust CAN be a problem when aggressive rust extends into the area where the tire bead seals against the rim or extreme rust consumes a lot of a rim, but judging from what I can see in the photo, I think the advise given above is right.
Gradiens super tenui glacie.
Old 10-04-2016, 08:40 AM   #4
2016 26' Flying Cloud
Southlake , Texas
After wire brushing, I would treat the wheel with a rust converter. Wire brushing will not get all the rust and it will soon eat thru the new paint. Some of the rust converters also act as a primer for painting.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is online now   Reply With Quote
Old 10-04-2016, 08:51 AM   #5
Southlake , Texas
If rust is so bad that it causes air loss, clean up the rusted area and use JB Weld to fill the pits. Sand smooth and paint. I have done this several time on classic cars.
Equalizer Hitch
Southlake, TX
WBCCI
Old 10-04-2016, 09:02 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
What is pictured is not the sealing area between tire and rim. While rust is always an issue, as noted above clean it, paint it and you should be good.
If you want to go all in, remove the old tire, clean rim and powder coat it for a tougher finish.
>>>>>>>>>>>>>>Action
Old 10-04-2016, 09:48 AM   #7
Thank you for the peace of mind!
When I take the tires off, how will I know if I have the infamous split rim or not?
Thanks again,
John
Old 10-04-2016, 11:42 AM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You don't have to take the tires off to know that. Your pictures confirm that you do NOT have split rims. (however your tires are shot) If you would like to know more about split rims go here. http://www.4wdonline.com/Wheels/Split.html
Split rims are still used in commercial application. Just not passenger vehicle applications.
>>>>>>>>>>>Action
Old 10-04-2016, 12:06 PM   #9
Excellent. Thank you.
I will now be taking apart the hubs on my "complete axles" so that I can weld the shock bracket to the axle.
I must have missed the part in the conversation between delivery and bolt-on.
No install instructions, no returned phone calls.. I'm going to guess and say some vets out there have a good idea where I went to get them.
Life lessons.
John
Old 10-04-2016, 12:11 PM   #10
charlevoix , Michigan
You could get the rims power coated . A friend did that with a boat trailer with rusty rims . Looks great
Waterdog is offline   Reply With Quote
Old 10-04-2016, 12:28 PM   #11
1977 31' Sovereign
Lynnwood , Washington
1) Like others have said, clean rims with wire wheel and paint.
2) Install inner tubes. Nothing beats old school.
Tom
TomKirk is offline   Reply With Quote
Old 10-04-2016, 01:11 PM   #12
Old Sailor
McArthur's Avatar
1983 34' Excella
Victoria , Texas
I wouldn't powder coat anything. I've seen too much of that stuff flake off and the rust comes right back. I would sand and paint them with POR15. That will last just about forever.
'82 Excella 34' "AlumaLady"
'06 Ram 2500 Lonestar
"Mollie Bug" The Boston Terrier
WBCCI #4456 - Born to Cruise
McArthur is offline   Reply With Quote
Old 10-04-2016, 01:54 PM   #13
2000 30' Excella
Toledo , Ohio
You could always get them sandblasted
woodfox45 is offline   Reply With Quote
Old 10-04-2016, 04:21 PM   #14
1976 31' Sovereign
Oswego , Illinois
Whether sand blast or wire brush if don't use good primer that stops rust it will come again. I had flat bed rims and trailer blasted 2 yrs. ago and painted, now rust forming. They were primed by shop that painted trailer, but dif. paint than used on rims. This shop rebuilds semi trailers and container chassis for 4 railroads, the paint used on trailer same as there customers. Bill
Replacement rim and tires Culcha Wheel Wells 10 08-14-2016 06:16 PM
15" rim vs. 16" rim ? Easyrider06 Tires 154 12-18-2015 04:18 PM
Tires and Rim Load Range Capability--Please Help KYAirstream Tires 31 07-27-2014 11:00 AM
Right Side Tires Wearing on the Outside Edge halimer Tires 8 06-24-2010 04:07 PM
