Old 10-04-2016, 06:35 PM   #15
2003 31' Classic
Terra Alta , West Virginia
POR 15.... AFTER SANDING. Pain't over the POR 15.
You'll be good for a very long time.
Dave
wvstreamer is offline   Reply With Quote
Old 10-05-2016, 01:43 PM   #16
captainjohn's Avatar
St. Michaels , Maryland
Name:	ImageUploadedByAirstream Forums1475696549.665595.jpg
ID:	272925Click image for larger version
Name:	ImageUploadedByAirstream Forums1475696572.509980.jpg
ID:	272926Click image for larger version
Name:	ImageUploadedByAirstream Forums1475696586.932717.jpg
All primed up!
Thanks for the input.
John
captainjohn is offline   Reply With Quote
Old 10-05-2016, 02:40 PM   #17
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Lookin' Good!
>>>>>>>>>>Action
Old 10-06-2016, 07:25 PM   #18
Name:	ImageUploadedByAirstream Forums1475803542.751212.jpg
Old 10-07-2016, 10:26 AM   #19
Ravenna , Ohio
Originally Posted by TomKirk View Post
1) Like others have said, clean rims with wire wheel and paint.
2) Install inner tubes. Nothing beats old school.
Tom
Using inner tube on tubeless tire is not a good idea. Neither is using just any tube on a radial tire (radial tubes are different than bias tubes.
Tube in tubeless tire can cause pressure issues as air can get trapped between tube and tire only to leak out slowly over days and weeks of use which means you need to monitor pressure constantly till the pressure stabilizes.
Tireman9 is offline   Reply With Quote
Old 10-07-2016, 10:33 AM   #20
Ravenna , Ohio
Cleaning and paint may be a good solution unless the rust is actually flaking steel which I think is seen in your pictures.
Surface rust should not be an issue.
POR15 and powder coat can work but you may cause other problems in the bead seat area as those thick coatings can actually cause bead seating problems. I did work on this issue when a car company decided to re-paint a few hundred wheels to change from silver to black. The 2nd coat was thick and when added to the original coat resulted in a number of wheels being too large for proper bead seating.
Personally after removing rust I would inspect the wheel for pits which indicates that material has been lost. If no significant steel has flaked off then clean all oil, and tire lube off. Thin coat of spray Rustolium primer and Rustolium spray silver should works well.
Replacement rim and tires Culcha Wheel Wells 10 08-14-2016 06:16 PM
15" rim vs. 16" rim ? Easyrider06 Tires 154 12-18-2015 04:18 PM
Tires and Rim Load Range Capability--Please Help KYAirstream Tires 31 07-27-2014 11:00 AM
Right Side Tires Wearing on the Outside Edge halimer Tires 8 06-24-2010 04:07 PM
